AIberto Posted October 30, 2014 Posted October 30, 2014 ;;Get MAC add. (defun GetNetMac (/id lox serv wmiobj) (setq WMIobj (vlax-create-object "wbemScripting.SwbemLocator") serv (vlax-invoke WMIobj 'ConnectServer "." "\\root\\cimv2" "" "" "" "" 128 nil ) lox (vlax-invoke serv 'ExecQuery "SELECT * FROM Win32_NetworkAdapter" ) ) (vl-catch-all-apply (function (lambda () (vlax-for item lox (if (and (setq name (vlax-get item "Manufacturer")) (not (wcmatch name "Microsoft*,VMware*")) (setq id (vlax-get item "MACAddress")) ) (exit) ) ) ) ) ) (mapcar 'vlax-release-object (list lox serv WMIobj)) id ) ;;Get NET Time (defun net_time (/ http date) (setq http (vla-GetInterfaceObject *acad* "Microsoft.XMLHTTP") ) (vla-open http "Post" "http://fsxm.mjtd.com/datetime.php" :vlax-false );; (vlax-invoke-method http 'send); (while (/= (vlax-get-property http 'readystate) 4)) (setq date (vlax-get-property http 'responsetext)); (vlax-release-object http) (fx-replace (substr date 1 10) "-" "") ) (defun fx-replace (str old new / len po start) (setq len (strlen new)) (setq start 0) (while (setq po (vl-string-search old str start)) (setq str (vl-string-subst new old str po)) (setq start (+ po len)) ) str ) Quote
BIGAL Posted October 31, 2014 Posted October 31, 2014 Moderator HUH ? Alberto what is your aim here by posting these lisps ? Would it not be better to just provide a list of every one you have and post it here with a description and link. Then people can decide if its usefull rather than what seems like random programs that you use, a lot of your recent posts do not appear to be your work. I have around 300+ programs but I dont randomly post them. Quote
AIberto Posted October 31, 2014 Author Posted October 31, 2014 sorry for my poor english, what's this mean ? a lot of your recent posts do not appear to be your work. Quote
hanhphuc Posted October 31, 2014 Posted October 31, 2014 a lot of your recent posts do not appear to be your work. If the codes are written by yourself is more meaningful to share. why not you give a try? (defun net_time ....) what's the usage of getting net time? we normally use this method: (rtos(getvar "cdate")2 0) Quote
