souvik Posted November 1, 2014 Posted November 1, 2014 I need to assign a cumulative distance chainage at a polyline which have some intersections. The distance chainage should be in negative and positive from 0.00. I will pick the o.oo point and the other chainage will be denoted automatically. I'm attaching a image. Please help me in this matter. Quote
Tharwat Posted November 2, 2014 Posted November 2, 2014 Try this draft and let me know . (defun c:Test (/ _t s p pt st nd vl lst lft rgt en i ss ins) ;; Tharwat 02.11.2014 ;; ;; ;; (defun _t (p v) (entmakex (list '(0 . "TEXT") (cons 10 (trans p 1 0)) (cons 11 (trans p 1 0)) (cons 1 v) (cons 7 (getvar 'TEXTSTYLE)) (cons 40 (getvar 'TEXTSIZE)) '(50 . 1.5708) '(71 . 0) '(72 . 2) '(73 . 0) ) ) ) (princ "\n << Pick LwPolyline : >>") (if (and (setq s (ssget "_+.:S:E:L" '((0 . "LWPOLYLINE") (-4 . "<NOT") (-4 . "<>") (42 . 0.0) (-4 . "NOT>") ) ) ) (setq p (getpoint "\n Specify Origin point on Selected LwPolyline :" ) ) ) (progn (setq pt (vlax-curve-getclosestpointto (setq en (ssname s 0)) p) st (vlax-curve-getstartpoint en) nd (vlax-curve-getendpoint en) vl (vlax-ename->vla-object en) ) (foreach x (entget en) (if (eq (car x) 10) (setq lst (cons (list (cadr x) (caddr x)) lst)) ) ) (if (< (car st) (car nd)) (setq lft st rgt nd ) (setq lft nd rgt st ) ) (if (setq ss (ssget "_F" lst)) (progn (if (ssmemb en ss) (ssdel en ss) ) (repeat (setq i (sslength ss)) (if (setq ins (vlax-invoke vl 'intersectwith (vlax-ename->vla-object (ssname ss (setq i (1- i)))) acextendnone ) ) (if (< (car ins) (car p)) (_t ins (strcat "-" (rtos (car ins) 2))) (_t ins (rtos (car ins) 2)) ) ) ) (_t pt "0.0") (_t lft (strcat "-" (rtos (car lft) 2))) (_t rgt (rtos (car rgt) 2)) ) ) ) ) (princ) )(vl-load-com) Quote
