Wesley_Amsterdam Posted November 4, 2014 Posted November 4, 2014 Hi all, I have a drawing with z-coordinates in it as text. I would like to export all the text-objects with their x- and y-coordinates, and use the text content for the z-coordinate. Find the example attatched. I couldn't find anything with a websearch. Text2excel.dwg Quote
MSasu Posted November 4, 2014 Posted November 4, 2014 Please check the built-in DATAEXTRACTION command. Apply it only for text entities and retain the Position X, Position Y and Value properties. Quote
Tharwat Posted November 4, 2014 Posted November 4, 2014 (edited) Try this . (defun c:Test (/ ss f o) ;; Tharwat 05.11.2014 ;; ;; Export Texts' values to Excel ;; (princ "\n << Select Texts to export to Excel : >>") (if (and (setq ss (ssget '((0 . "TEXT") ) ) ) (setq f (getfiled "Save as :" (getvar 'DWGPREFIX) "csv" 1)) ) (progn (setq o (open f "w")) (write-line "X-coordinate of text;Y-coordinate of text;Z-coordinate of text value" o ) ((lambda (i / sn p e) (while (setq sn (ssname ss (setq i (1+ i)))) (write-line (strcat (rtos (car (setq p (cdr (assoc 10 (setq e (entget sn)))))) 2 ) ";" (rtos (cadr p) 2) ";" (cdr (assoc 1 e)) ) o ) ) ) -1 ) (close o) ) ) (princ) ) Edited November 5, 2014 by Tharwat Quote
Wesley_Amsterdam Posted November 5, 2014 Author Posted November 5, 2014 Hi Tharwat, Thanks for the tool! I miss the x- and y-coordinates in the list. Regards, Wesley Quote
Tharwat Posted November 5, 2014 Posted November 5, 2014 I miss the x- and y-coordinates in the list. Are you talking about the X and Y of the Text location ? Show the outcome of the program as best as you looking for to allow me to write it for in one go . Quote
Wesley_Amsterdam Posted November 5, 2014 Author Posted November 5, 2014 Hi Tharwat, The outcome should look like this. Thnx Quote
Tharwat Posted November 5, 2014 Posted November 5, 2014 I updated the routine above , try it and let me know . Quote
Wesley_Amsterdam Posted November 5, 2014 Author Posted November 5, 2014 Thnks Tharwat! Works great! Regards, Wesley Quote
Tharwat Posted November 5, 2014 Posted November 5, 2014 Thnks Tharwat! Works great! Regards, Wesley You're welcome . Happy to help Quote
