Have such a plugin can formatting Dcl to Lisp ?
Like this:
Before formatting
DCL file
roughness
:dialog{ label="Roughness ";
spacer;
:row{
 :column{
  :image_button{ key = "RM"; aspect_ratio = 1; width = 8; fixed_width = true; color = -2; allow_accept = true; }
  :image_button{ key = "UN"; aspect_ratio = 1; width = 8; fixed_width = true; color = -2; allow_accept = true; }
  :image_button{ key = "BS"; aspect_ratio = 1; width = 8; fixed_width = true; color = -2; allow_accept = true; }
 :list_box{ key="RV"; value=8; width=16; height=14; allow_accept=true; }
:row{
 :errtile{ width= 14; }
 :edit_box{ label = "Scale:"; key = "SC"; edit_width = 3; }
ok_cancel;
After the formatting
Lisp file
        strl        '("roughness:dialog{                  "
                 "label=\"Roughness \";                  "
                 "spacer;                          "
                 ":row{                          "
                 "  :column{                          "
                 "     :image_button{ key = \"RM\";"
                 "      aspect_ratio = 1;          "
                 "      width = 8;                  "
                 "      fixed_width = true;          "
                 "      color = -2;                  "
                 "      allow_accept = true;          "
                 "     :image_button{                  "
                 "      key = \"UN\";                  "
                 "      width = 8;                  "
                 "      color = -2;                  "
                 "     :image_button{ key = \"BS\";"
                 "      width = 8;                  "
                 "      color = -2;                  "
                 "   :list_box{                  "
                 "    key=\"RV\";                  "
                 "    value=8;                          "
                 "    width=16;                  "
                 "    height=14;                  "
                 "    allow_accept=true;          "
                 "  :row{                          "
                 "    :errtile{                  "
                 "     width= 14;                  "
                 "    :edit_box{                  "
                 "     label = \"Scale:\";          "
                 "     key = \"SC\";                  "
                 "     edit_width = 3;                  "
                 "    ok_cancel;                  "
 ) ;_DCL
Hi Alberto .
Your formatting of the dcl codes is correct .
Hi Tharwat
Nice to meet you !
This is formatting by manual , So tired !!! :( I means, Have a tool can formatting automatically ???
Hi Tharwat
Nice to meet you !
Thank you :)
Nothing comes easily ;)
Assuming you are writing the code using a code editor (and if not, why not?!), use the standard editing utilities offered by most code editors to add the necessary quotation marks.
For example, find/replace " with \"
Prefix all lines with "
Append all lines with "
Job done. :)
Reading and rewriting the DCL file strings into a txt file or a list would take care of this process ;) .
what i use to do is similar with Tharwat
(defun dcl->lst	( fn / str fn f l)
 (if (and fn (setq f (open fn "r")))
   (while (setq str (read-line f)) (setq l (cons str l)))
   ) ;_ end of if
 (close f)
 (reverse l)
 ) ;_ end of defun
using console or vlide Load Selection
(setq tmp (dcl->lst (getfiled "" "" "dcl" ))
copy the list from console then paste it to editor, then Format Selection
still a bit manually not fully automated.
But there is no need - this means saving the code to a separate file, loading & running the program to process the file, selecting the saved file to be processed, opening the processed file & copying the results back to the editor. In my opinion it is far easier to simply select the code in the editor and perform the necessary operations directly to the selection - I could probably do this quicker than running a separate program.
I used to write in Dcl format then retrieve the attributes to a list into the Vlide then copy & paste them into the target program , but nowadays I am able to write the dcl attributes in my program without the need of all these previous said process directly . :)
hanhphuc , it is recommended to have the progn function in your program to avoid the error message if the user did not reach correct file at first . :)
Thank you for the advise, noted :)
normally save as dcl, syntax & color for me easier in dcl editor.
In lisp editor, semi-colon ";" is comment, or string " " is pink color
so double handling job :(
however noted your advise, i should direct practise in lisp editor :)
Thank you.
   ) ;_ end of if
 (close f)
 (reverse l)
 ) ;_ end of defun
Many Thanks , my friend hanhphuc.
My idea is the same, but , I think You can also improve.
1.Reading dcl file
2.Writing the "formatting code" into a txt file. not in command bar
Assuming you are using the Visual LISP IDE, simply change the language to DCL:
Tools > Window Attributes > Syntax Coloring > DCL
No need to save to a separate file, but each to their own I suppose :)
oh!!:D silly me! Good tips Thank you Lee :thumbsup:!!
