plecs Posted November 8, 2014 Posted November 8, 2014 Can someone help me with count list if they are the same I list that I need count list if they are the same Thanks in advance (("123" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0") ("123" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0") ("122" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0") ("122" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("122" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("223" "0" "0" "Hz" "0" "0" "0" "0" "ss" "0") ("223" "0" "0" "Hz" "0" "0" "0" "0" "ss" "0") ("223" "0" "0" "Hz" "0" "0" "0" "0" "ss" "0")) Quote
hanhphuc Posted November 8, 2014 Posted November 8, 2014 i'm not sure but can try Express tool :acetutil ([color="red"]acet-list-remove-duplicates[/color] '(("123" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0") ("123" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0") ("122" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0") ("122" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("122" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("223" "0" "0" "Hz" "0" "0" "0" "0" "ss" "0") ("223" "0" "0" "Hz" "0" "0" "0" "0" "ss" "0") ("223" "0" "0" "Hz" "0" "0" "0" "0" "ss" "0")) [color="red"]0[/color] ) or For code learning try this could help? Unique&Duplicate Quote
plecs Posted November 8, 2014 Author Posted November 8, 2014 thank you, goes well but how to count lists are identical Quote
hanhphuc Posted November 8, 2014 Posted November 8, 2014 thank you,goes well but how to count lists are identical I'm not very clear about identical, Maybe you can try these functions to test the list Vl-remove-if Vl-some Vl-every You can start test (length lst) compare etc.. Quote
Tharwat Posted November 8, 2014 Posted November 8, 2014 (setq l '(("123" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0") ("123" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0") ("122" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0") ("122" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("122" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") ("223" "0" "0" "Hz" "0" "0" "0" "0" "ss" "0") ("223" "0" "0" "Hz" "0" "0" "0" "0" "ss" "0") ("223" "0" "0" "Hz" "0" "0" "0" "0" "ss" "0") ) ) (foreach x l (if (setq a (assoc x lst)) (setq lst (subst (cons x (1+ (cdr a))) a lst)) (setq lst (cons (cons x 1) lst)) ) ) Quote
Lee Mac Posted November 8, 2014 Posted November 8, 2014 how to count lists are identical You can use my Count Items functions from here: _$ (LM:countitems l) ( (("123" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0") . 2) (("122" "0" "0" "Hz" "0" "0" "0" "0" "ac" "0") . 1) (("122" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") . 2) (("12" "0" "0" "Hz" "0" "0" "0" "0" "bb" "0") . 4) (("223" "0" "0" "Hz" "0" "0" "0" "0" "ss" "0") . 3) ) As hanhphuc has kindly recommended: try this could help?Unique&Duplicate Quote
Tharwat Posted November 11, 2014 Posted November 11, 2014 wow it works thanks a lot Which codes you are indicating to ? Quote
