CLS Posted November 13, 2014 Share Posted November 13, 2014 Hi everyone, I have looked and searched through this forum and I couldn't find the answer. If this is asked before and solved, then please direct me towards the topic. I am sorry if I ask something that has been answered before. Here is what I try to accomplish: I made a dynamic block for a butterfly valve with attributes. Some of these attributes are hidden, some don't. I am having trouble with the hidden (not visible) attributes. I want to make use of the 'find' commando in AutoCad and want to find all butterfly valves. I could do this when an attribute is visible and filled in with the text butterfly valve. Problem is, I don't want this text to be visible, yet I do want the find commando to find me this block. I would like this attribute to be hidden, but searchable and that the find commando will return me the results listing all butterfly valves in a dwg. Is this at all possible? I hope I explained this well enough, if not, feel free to ask me. Thanks for reading! Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 13, 2014 Share Posted November 13, 2014 Are the attributes hidden using a visibility parameter or by setting their own visible property to off? All I can say is that I have exactly zero success with attributes and visibility parameters playing nicely together - they just don't seem to get on. If YOU don't need to read this data other possibilities is VERY small text or put your attributes on a non plotting layer. That way it can be read by FIND (I think) but not so obvious to you. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 14, 2014 Share Posted November 14, 2014 You can do it with a lisp search block name and attribute Tagname also visibilty and change value. There heaps of examples maybe start at http://www.lee-mac.com Quote Link to comment Share on other sites More sharing options...
CLS Posted November 14, 2014 Author Share Posted November 14, 2014 The attributes are hidden by setting their own visibility property off. I need the visibility paramater for other stuff. And since AutoCAD only supports one Visibility paramater per block, I cannot afford to use it for other stuff. I know it is possible to fake multiple visibility paramaters though. Sorry that bit was offtopic. The link to Lee Mac's programs is really useful. I forgot to look at this guru's website. What I would like is a combination of his Dynamic Block Counter and the find command in AutoCAD. And what I am trying to find through the find command is hidden in an attribute. I tried the suggestion of you Dave, to have it not hidden but very small, but it is not the preferred way to me. Thanks for your suggestions guys, really appreciated! Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 14, 2014 Share Posted November 14, 2014 I tried the suggestion of you Dave, to have it not hidden but very small, but it is not the preferred way to me.Its not a preferred solution of mine either but it is the way Autodesk appear to use in their Electrical package. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 15, 2014 Share Posted November 15, 2014 Post a sample dwg with a filled in butterfly valve, then its possible to snoop with lisp. Quote Link to comment Share on other sites More sharing options...
