sadhu Posted November 19, 2014 Posted November 19, 2014 I use the code below to add a polyline to a block made in lisp. I need help for a similar code (similar format and syntax) to add a 1. solid hatch (color by layer) 2. and a circle. to the block. (vla-put-closed (vlax-invoke Blk_Nme ; block name 'AddLightWeightPolyline (list (car pt1) (cadr pt1) (car pt2) (cadr pt2) (car pt3) (cadr pt3) ) ) :vlax-true ) Code syntax to substitute 'AddLightWeightPolyline . All help and/or indication is appreciated. I would like to avoid using ENTMAKE. Quote
Tharwat Posted November 19, 2014 Posted November 19, 2014 Hi , Try this and change values to suit your needs of them . (defun c:Test (/ o _add_circle_+_solid) ;; Tharwat 19.11.2014 ;; (princ "\n Pick a sinlge Block to addd Circle with Hatch :") (if (setq o (ssget "_+.:S:E:L" '((0 . "INSERT")))) (progn (defun _add_circle_+_solid (spc pnt rad / c h) ;; spc = Block definition ;; ;; pnt = Circle insertion point ;; ;; rad = Radius of Circle ;; (if (and (setq c (vla-addcircle spc (vlax-3d-point pnt) rad)) (setq h (vla-addhatch spc acHatchPatternTypePredefined "SOLID" :vlax-true ) ) ) (progn (vlax-invoke h 'AppendOuterLoop (list c)) (vlax-invoke h 'Evaluate) ) ) ) (_add_circle_+_solid (vla-item (vla-get-blocks (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) ) (cdr (assoc 2 (entget (ssname o 0)))) ) '(0. 0. 0.) 1.0 ) (vla-regen doc acallviewports) ) ) (princ) )(vl-load-com) Quote
sadhu Posted November 20, 2014 Author Posted November 20, 2014 Thank you Tharwat for your reply and suggestion. The code below is what I have for making an anonymous block. What I'm trying to do is solid-hatch the closed polyline and add a circle. I tried to integrate your code but without success. (defun c:pttest() (vl-load-com) (setq radiusPT 5 profon 0.5 pt0 '(0 0 0) Blk_Nme "New_block" *doc (cond (*doc)((vla-get-ActiveDocument (vlax-get-acad-object)))) spc (if (or (eq AcModelSpace (vla-get-ActiveSpace *doc)) (eq :vlax-true (vla-get-MSpace *doc))) (vla-get-ModelSpace *doc) (vla-get-PaperSpace *doc)) BOX_type "steel 0.5" lay "0" ) ;insertion points (setq ins_Pt(getpoint "\n Select insertion point") x1(car ins_Pt) y1(cadr ins_Pt) x2 (- x1 0.2 ) y2 (- y1 0.2 ) boxtype_ins_pt (list x2 y2) ; attribute insertion point p1 (list (- x1 radiusPT) (- y1 profon)) ; for solid hatch p2 (list (- x1 radiusPT) (+ y1 profon)) p3 (list (+ x1 radiusPT) (+ y1 profon)) p4 (list (+ x1 radiusPT) (- y1 profon)) L1 0.02 ptl1 (list (- x1 radiusPT L1) y1) ptl2 (list (+ x1 radiusPT L1) y1) ptl3 (list x1 (+ y1 profon L1)) ptl4 (list x1 (- y1 profon L1)) ) ; make block (setq Blk_Nme (vlax-invoke (vla-get-Blocks *doc) 'Add (list (car ins_Pt) (cadr ins_Pt) 0.) "*U" ) ) ; put closed polyline (vla-put-closed (vlax-invoke Blk_Nme 'AddLightWeightPolyline (list (car p1) (cadr p1) (car p2) (cadr p2) (car p3) (cadr p3) (car p4) (cadr p4)) ) :vlax-true ) ; code to hatch closed polyline and be part of the block ; code to add a circle to the block "Blk_Nme" with center "ins_Pt" and radius "radiusPT" ;insert attribute BOX_type (vlax-invoke Blk_Nme 'AddAttribute 0.02 ;text height acAttributeModePreset; ; attribute visibile "BOX_type" (list (car boxtype_ins_pt) (cadr boxtype_ins_pt) 0.) "BOX_type tag" ; attribute tag BOX_type ; attribute value ) ;insert block (vla-put-layer (setq bObj (vlax-invoke spc ;mSpace 'InsertBlock (setq p1 (list (car ins_Pt) (cadr ins_Pt) 0. ) ) (vla-get-Name Blk_Nme) 1. 1. 1. 0. ) ) lay ) ) Quote
