Results 1 to 2 of 2
    Full Member
    dal-designs's Computer Details
    Windows 7
    HP Compaq Elite 8300 SFF
    dal-designs's Discipline Details
    Designer in Oil and Gas Industry
    facilities planning (retail/wholesale fuels and chemicals) aerial surveying and GIS mapping; building design, facilities planning, land development
    AutoCAD 2015
    Feb 2014
    Victoria, Texas
    Question Multileaders and Layout Space Text Height
    We're looking at implementing multileaders instead of quleaders in my office, and so I've been tasked with figuring out how to do it (being as I am the least senior, most peon-ish person in my department).
    I've messed with them before, so I mostly have it figured out. There is one thing that eludes me- despite much Googling and AutoCADding for Dummies and (the most worthless of all) AutoCAD's F1.
    My question is: when mleaders are annotative, where do you set the 'paper space text height'? I know I can change the model space text height (among other things) through Properties, but that seems to defeat the purpose of having annotative properties.
    Last edited by dal-designs; 21st Nov 2014 at 04:53 pm. Reason: punctuation matters
    Sucking at something is the first step to being kinda good at it
    Full Member
    AutoCAD 2014
    Mar 2014
    The text height is governed by the text style you are using. You will need to great an annotative text style first. Then in the MLeader Style Manager, pick the MLeader you want to modify, go to the Content tab, pick the MText option in the Multileader type pull down menu. A whole bunch of options will then appear. Under Text Options, browse to the Text style you want to use. The Text Height option should default to the text height you chose when you created your Text style. I'm assuming that if your Text style is not annotative, the Text height option will not be grayed out.
  1. How to setup Model Space Dimension Text Height then make it annotative
    By JamFam in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Aug 2010, 11:20 pm
  2. changing text/mtext to multileaders...
    By chrisdarmanin in forum AutoCAD General
    Last Post: 11th Nov 2009, 03:02 pm
  3. drawing visible in layout space but not in model space
    By 3dsmaxed in forum AutoCAD Drawing Management & Output
    Last Post: 15th Jul 2009, 11:20 am
  4. text height in layout
    By biohazarus in forum AutoCAD Drawing Management & Output
    Last Post: 9th May 2009, 06:14 am
  5. Replies: 10
    Last Post: 16th Oct 2007, 12:41 am
Tags for this Thread
