ColinHolloway Posted December 1, 2014 Share Posted December 1, 2014 Hi All, I am trying to use a point that I am passing to the .NET routine to place a pipe supports on a Pipe in Plane 3D. This issue is that when I pass the point to the command _PlantPipeSupportConvert, it returns "Point must be on a pipe or piping component". Using LISP the only way I have found to do this is to set the Aperture to 50 and turn OSnap Nearest on so it selects the point *ON* the pipe. This method is really clumsy and fails if the zoom isn't suitable for the snap to work correctly. Has anyone come across a solution to allow a point to be selected and it recognizes that it is *ON* the pipe? Thanks in Advance, Colin Holloway Quote Link to comment Share on other sites More sharing options...
BlackBox Posted December 3, 2014 Share Posted December 3, 2014 Civil 3D Pipes have, what I believe to be, a similar issue in that the 'pipe' is a Line with Properties that manage the horizontal pipe width, and vertical pipe height, etc. which end up needing to be calculated if one is attempting to obtain a Point3d for either top or bottom of either inner or outer pipe diameter (i.e., where a pipe support might be located). HTH Quote Link to comment Share on other sites More sharing options...
