hamidciv Posted December 5, 2014 Share Posted December 5, 2014 hi dear all :(i want draw two line be parallel like mline command but with Specified distance, for draw two horizontial lines i write correspond code, but for this case i confused. i know that should draw lines with angle=90 for case but I did not succeed. please help me Quote Link to comment Share on other sites More sharing options...
zaphod Posted December 5, 2014 Share Posted December 5, 2014 try the offset command? Quote Link to comment Share on other sites More sharing options...
Debalance Posted December 5, 2014 Share Posted December 5, 2014 Why don't you just use the OFFSET command? I think this is the easiest way. Quote Link to comment Share on other sites More sharing options...
hamidciv Posted December 5, 2014 Author Share Posted December 5, 2014 I wanted to write another command other than offset ,As you mentioned, the offset is easily done. i have another question , how i can of one point that i define it with getpoint command ,I draw the line determined by the length and angle??? for example : (setq p (getpoint)), i want from p point , draw line with 10cm length and 45 degress, how do this? thanks Quote Link to comment Share on other sites More sharing options...
zaphod Posted December 5, 2014 Share Posted December 5, 2014 is this what you are trying to do? Quote Link to comment Share on other sites More sharing options...
hamidciv Posted December 5, 2014 Author Share Posted December 5, 2014 dear zaphod you image sent, is normal method in autocad , my goal is write this command in autolisp? friends please help me. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 5, 2014 Share Posted December 5, 2014 10 Their is heaps of stuff about draw two lines in one go just search here for "multi line" so many diferent combinations are available. (defun dtr (a) (* pi (/ a 180.0)) ) ;example (setq dist (getdist "\enter distance")) (setq ang (getreal "enter angle)) (setq ang (dtr ang)) (setq pt2 (polar pt1 ang dist)) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 5, 2014 Share Posted December 5, 2014 I want draw two line be parallel like mline command but with specified distance As an alternative, you could configure your MLine style such that the MLine elements are 1 unit apart, and then use the 'Scale' option of the MLine command to control the distance between the lines - the MLine could be subsequently exploded (or use this) if lines/polylines are required. This way, you would still have the dynamic visual preview offered by the MLine command. Quote Link to comment Share on other sites More sharing options...
hamidciv Posted December 6, 2014 Author Share Posted December 6, 2014 hi dear lee mac thanks a lot for help me, You're really master. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 6, 2014 Share Posted December 6, 2014 You're most welcome hamidciv, happy to help. Quote Link to comment Share on other sites More sharing options...
