Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Full Member
    AutoCAD 2008
    Sep 2012
    82
    Default I want lisp to get label at the polyline starting edge and ending edge
    I want lisp to get at the beginning and end of each polyline of the Elevation Label
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    I moved your thread to the AutoLISP, Visual LISP & DCL Forum.
    Please post in the appropriate forum most closely related to your question.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    A start for you maybe have a go at writing a lisp using vl you can get co-ords of plines and their elevation
    [code]
    (vl-load-com)
    (setq obj1 (vlax-ename->vla-object (car (entsel "\npick pline"))))
    (setq coords (vlax-safearray->list (vlax-variant-value(vla-get-coordinates obj1)))) ; 1st 2 variables are start last 2 are end pt
    (setq ht (vla-get-elevation obj1)) ; height of pline
    [code]
    Full Member
    AutoCAD 2008
    Sep 2012
    82
    i have got it already lisp file but in this lisp file little be mistake. this file was generate only start edge. i need generated with Polyline both of side edge.
    (defun C:MCL ()
    (setq ss (ssget'((0 . "LWPOLYLINE"))))
    (setq sslngth (sslength ss))
    (Setq idx 0)
    (repeat sslngth
    (setq ename (ssname ss (setq sslngth (1- sslngth))))
    (setq edata (entget ename))
    (setq xy (cdr (Assoc 38 edata)))
    (setq xy1(cdr (Assoc 10 edata)))
    (setq xx(rtos xy 2 3))
    (command "text" xy1 2 30 xx "")
  5. #5
    Super Member hanhphuc's Avatar
    AutoCAD 2007
    Apr 2013
    Happy Garden
    749
    Quote Originally Posted by sanju2323 View Post
    Try..
    Code:
    (defun c:test (/ ss i ed p sz)
    (initget 6)
    (if (not(setq sz (getdist "\nText size : ")))
    (setq sz (getvar "textsize")))
      (prompt "\nSelect Contour.. ")
      (if (setq ss (ssget ":L" '((0 . "LWPOLYLINE"))))
          (setq ed (entget (ssname ss (setq i (1- i)))))
          (foreach x (list (car (setq p (vl-remove-if ''((x) (/= (car x) 10)) ed))) (last p))
    	(entmakex (list	'(0 . "TEXT")'(8 . "CONTOUR LABEL")
    			(cons 1 (rtos (cdr (assoc 38 ed)) 2 3))
    			(cons 40 sz)
    			x
    			) ;_ end of list
    		  ) ;_ end of entmakex
    	) ;_ end of foreach
          ) ;_ end of repeat
        ) ;_ end of if
      ) ;_ end of defun
    i hope BIGAL can understand im online now to help OP
    _$ ( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" )
    ; error: too many arguments
  6. #6
    Full Member
    AutoCAD 2008
    Sep 2012
    82
    Thank You Sir Its Work
  7. #7
    AutoCAD 2007
    Apr 2013
    Happy Garden
    749
    you are welcome, please read this regarding code Tag for newbie
    http://www.cadtutor.net/forum/showth...ing-guidelines
  8. #8
    Full Member
    AutoCAD 2008
    Sep 2012
    82
    can you make changes in LISP. For example set text height, "2" and select polyline or spline
  9. #9
    AutoCAD 2007
    Apr 2013
    Happy Garden
    749
    #5 updated (in red)
    you can set default,
    command: textsize
  10. #10
    Full Member
    AutoCAD 2008
    Sep 2012
    82
    sir can you give me last time changes in the lisp file? i want to label generate the single time at closest Polyline.
  1. Need help to create polyline edge road
    By tieptouch in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Mar 2014, 09:04 am
  2. snapping to an edge
    By raymarcher in forum AutoCAD Beginners' Area
    Last Post: 12th May 2011, 04:32 pm
  3. Help moving the edge of a circle precisely to the edge of a line
    By berol in forum AutoCAD Beginners' Area
    Last Post: 15th Feb 2011, 05:05 pm
  4. Opening a polyline on the edge selected
    By DWG Destroyer in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Nov 2009, 08:26 pm
  5. Help w/ Ogee edge
    By controversia in forum AutoCAD 3D Modelling & Rendering
    Last Post: 7th May 2008, 04:14 am
Tags for this Thread
