andy_lee Posted December 16, 2014 Share Posted December 16, 2014 Hi guys Can help me to supplement the "dot" function ? Thanks a lot! ;;http://bbs.xdcad.org/thread-678248-1-1.html ;;by huang (defun C:myjoin(/ E H J LST N OBJ P11 P12 P21 P22 SS X) (defun twoEnt (e1 e2) (setq p11 (vlax-curve-getStartPoint e1)) (setq p12 (vlax-curve-getEndPoint e1)) (setq p21 (vlax-curve-getStartPoint e2)) (setq p22 (vlax-curve-getEndPoint e2)) (cond ((and (equal (det p11 p12 p21) 0) (equal (det p11 p12 p22) 0)) (setq H (car (Max-distance (list p11 p12 p21 p22)))) (setq obj (vlax-ename->vla-object e1)) (vlax-put obj 'StartPoint (car H)) (vlax-put obj 'EndPoint (cadr H)) ) ) ) (cond ((setq ss (ssget '((0 . "LINE")))) (repeat (setq n (sslength ss)) (setq e (ssname ss (setq n (1- n)))) (setq lst (cons e lst)) ) (foreach j lst (mapcar '(lambda (x) (cond ((and (entget x) (entget j)) (twoEnt j x)))) lst) ) ) ) (princ) ) ;;(Max-distance (getpt (ssget) 10))=>(((-2670.87 3701.22 0.0) (-1725.61 3689.13 0.0)) . 945.338) (defun Max-distance (H / D M MAXD P PAIR Q U V W) (setq Q (cdr (append H H (list (car H))))) (setq MaxD 0.0) (foreach U H (setq V (car Q)) (setq W (cadr Q)) (setq M (MJ:Mid V W)) (while (> (dot M U V) 0.0) (setq Q (cdr Q)) (setq V (car Q)) (setq W (cadr Q)) (setq M (MJ:Mid V W)) ) (setq D (distance U V)) (if (> D MaxD) (setq MaxD D Pair (list U V) ) ) ) (cons Pair MaxD) ) (defun MJ:Mid (P1 P2) (mapcar '(lambda (X Y) (* (+ X Y) 0.5)) P1 P2) ) ;;(det (getpoint)(getpoint)(getpoint)) (defun det (p1 p2 p3 / x2 y2) (setq x2 (car p2) y2 (cadr p2) ) (- (* (- x2 (car p3)) (- y2 (cadr p1))) (* (- x2 (car p1)) (- y2 (cadr p3))) ) ) Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted December 16, 2014 Share Posted December 16, 2014 The code is somewhat wrong... I don't quite know what should it do, but I guessed it should be something like this : ;;http://bbs.xdcad.org/thread-678248-1-1.html ;;by huang ;;mod by M.R. (defun c:myjoin (/ e h j lst n obj p11 p12 p21 p22 ss) (vl-load-com) (defun twoent (e1 e2) (setq p11 (vlax-curve-getstartpoint e1)) (setq p12 (vlax-curve-getendpoint e1)) (setq p21 (vlax-curve-getstartpoint e2)) (setq p22 (vlax-curve-getendpoint e2)) (if (and (equal (det p11 p12 p21) 0) (equal (det p11 p12 p22) 0) ) [highlight];=> if you want only WCS calculation leave this line, but if you want it 3D replace line with T[/highlight] (progn (setq h (car (max-distance (list p11 p12 p21 p22)))) (setq obj (vlax-ename->vla-object e1)) (vlax-put obj 'startpoint (car h)) (vlax-put obj 'endpoint (cadr h)) ) ) ) (cond ((setq ss (ssget '((0 . "LINE")))) (repeat (setq n (sslength ss)) (setq e (ssname ss (setq n (1- n)))) (setq lst (cons e lst)) ) (foreach j lst (mapcar '(lambda (x) (cond ((and (entget x) (entget j)) (twoent j x))) ) lst ) ) ) ) (princ) ) ;;(max-distance ptlst)=>(((-2670.87 3701.22 0.0) (-1725.61 3689.13 0.0)) . 945.338) (defun max-distance (h / d maxd pair q v) (setq q (cdr (append h h (list (car h))))) (setq maxd 0.0) (foreach u h (setq v (car (vl-sort q '(lambda (a b) (> (distance u a) (distance u b))) ) ) ) (setq d (distance u v)) (if (> d maxd) (setq maxd d pair (list u v) ) ) ) (cons pair maxd) ) ;;(det (getpoint)(getpoint)(getpoint)) (defun det (p1 p2 p3) (+ (* (car p1) (- (* (cadr p2) (caddr p3)) (* (cadr p3) (caddr p2))) ) (* (- (cadr p1)) (- (* (car p2) (caddr p3)) (* (car p3) (caddr p2))) ) (* (caddr p1) (- (* (car p2) (cadr p3)) (* (car p3) (cadr p2))) ) ) ) Quote Link to comment Share on other sites More sharing options...
andy_lee Posted December 17, 2014 Author Share Posted December 17, 2014 The code is somewhat wrong... I don't quite know what should it do, but I guessed it should be something like this : Thank you so much , marko. but , can't batch join . Should be like this: Quote Link to comment Share on other sites More sharing options...
andy_lee Posted December 17, 2014 Author Share Posted December 17, 2014 (defun dot (p1 p2 p3 / x1 y1) (setq x1 (car p1) y1 (cadr p1) ) (+ (* (- (car p2) x1) (- (car p3) x1)) (* (- (cadr p2) y1) (- (cadr p3) y1)) ) ) I find "dot" function ,But can't work normally Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted December 17, 2014 Share Posted December 17, 2014 I would suggest you that you use JOIN command for the same task... http://www.theswamp.org/index.php?topic=46124.0 ;Written by: Chris Wade ;small mod by M.R. (defun c:ja ( / *error* uFlag doc StopLoop SelSet SelLen LoopCT ) (vl-load-com) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (defun *error* (msg) (if doc (vla-EndUndoMark doc) ) (if msg (prompt msg) ) (princ) ) (while (= StopLoop nil) (princ "\nPlease select the objects that you would like to join : " ) (setq SelSet (ssget)) (cond ((/= SelSet nil) (vla-StartUndoMark doc) (setq SelLen (sslength SelSet)) (setq LoopCT 0) (while (< LoopCT SelLen) (vl-cmdf "._join" (ssname SelSet LoopCT) SelSet "") (setq LoopCT (+ LoopCT 1)) ) (setq StopLoop T) ) ) ) (*error* nil) ) I thought you wanted something like this : ;;by M.R. (defun c:myjoin ( / max-distance e ptlst n p1 p2 ss filter ch x ) ;;(max-distance ptlst)=>(((-2670.87 3701.22 0.0) (-1725.61 3689.13 0.0)) . 945.338) (defun max-distance ( h / d maxd pair q v ) (setq q h) (setq maxd 0.0) (foreach u h (setq v (car (vl-sort q '(lambda ( a b ) (> (distance u a) (distance u b))) ) ) ) (setq d (distance u v)) (if (> d maxd) (setq maxd d pair (list u v) ) ) ) (cons pair maxd) ) (initget "2D 3D") (setq ch (getkword "\n2D or 3D calculation [2D/3D] <3D> : ")) (if (null ch) (setq ch "3D") ) (setq filter (if (eq ch "3D") (list '(0 . "LINE")) (list '(0 . "LINE") '(-4 . "<and") '(-4 . "*,*,=") '(10 0.0 0.0 0.0) '(-4 . "*,*,=") '(11 0.0 0.0 0.0) '(-4 . "and>") ) ) ) (setq ss (ssget filter)) (repeat (setq n (sslength ss)) (setq e (ssname ss (setq n (1- n)))) (setq p1 (cdr (assoc 10 (entget e))) p2 (cdr (assoc 11 (entget e))) ) (setq ptlst (cons p1 ptlst) ptlst (cons p2 ptlst) ) ) (setq x (max-distance ptlst)) (entmake (list '(0 . "LINE") (cons 10 (caar x)) (cons 11 (cadar x)) '(62 . 1) ) ) (princ) ) Regards, M.R. Quote Link to comment Share on other sites More sharing options...
andy_lee Posted December 17, 2014 Author Share Posted December 17, 2014 I would suggest you that you use JOIN command for the same task...http://www.theswamp.org/index.php?topic=46124.0 Lee's routine is very nice!!! ;Written by: Chris Wade ;small mod by M.R. (defun c:ja ( / *error* uFlag doc StopLoop SelSet SelLen LoopCT ) (vl-load-com) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (defun *error* (msg) (if doc (vla-EndUndoMark doc) ) (if msg (prompt msg) ) (princ) ) (while (= StopLoop nil) (princ "\nPlease select the objects that you would like to join : " ) (setq SelSet (ssget)) (cond ((/= SelSet nil) (vla-StartUndoMark doc) (setq SelLen (sslength SelSet)) (setq LoopCT 0) (while (< LoopCT SelLen) (vl-cmdf "._join" (ssname SelSet LoopCT) SelSet "") (setq LoopCT (+ LoopCT 1)) ) (setq StopLoop T) ) ) ) (*error* nil) ) Thank you marko, this is good too ! but if can use for pline ,That would be more perfect !!! I thought you wanted something like this : ;;by M.R. (defun c:myjoin ( / max-distance e ptlst n p1 p2 ss filter ch x ) ;;(max-distance ptlst)=>(((-2670.87 3701.22 0.0) (-1725.61 3689.13 0.0)) . 945.338) (defun max-distance ( h / d maxd pair q v ) (setq q h) (setq maxd 0.0) (foreach u h (setq v (car (vl-sort q '(lambda ( a b ) (> (distance u a) (distance u b))) ) ) ) (setq d (distance u v)) (if (> d maxd) (setq maxd d pair (list u v) ) ) ) (cons pair maxd) ) (initget "2D 3D") (setq ch (getkword "\n2D or 3D calculation [2D/3D] <3D> : ")) (if (null ch) (setq ch "3D") ) (setq filter (if (eq ch "3D") (list '(0 . "LINE")) (list '(0 . "LINE") '(-4 . "<and") '(-4 . "*,*,=") '(10 0.0 0.0 0.0) '(-4 . "*,*,=") '(11 0.0 0.0 0.0) '(-4 . "and>") ) ) ) (setq ss (ssget filter)) (repeat (setq n (sslength ss)) (setq e (ssname ss (setq n (1- n)))) (setq p1 (cdr (assoc 10 (entget e))) p2 (cdr (assoc 11 (entget e))) ) (setq ptlst (cons p1 ptlst) ptlst (cons p2 ptlst) ) ) (setq x (max-distance ptlst)) (entmake (list '(0 . "LINE") (cons 10 (caar x)) (cons 11 (cadar x)) '(62 . 1) ) ) (princ) ) No, this is not I want. This can't batch merge Lines . Quote Link to comment Share on other sites More sharing options...
