I want choose a face of 3d entity , edge projection , This is possible ??
the edge is line.
I know a command is "_xedges", but this extract all edges ,
use copy edges ? Looks good , but need Multi- choice , and must
Specify a base point or displacement:
Specify a second point of displacement:
can simplify?
This is the effect after removed entity
Edited by AIberto
Try this:
(vl-cmdf "_solidedit" "_f" "_c" pause "" pause  pause "" "")
I know that this is off topic, but how did you make that GIF in AutoCAD?
Try this:
[ATTACH=CONFIG]52039[/ATTACH]
Hi GP , This is not what I need , This is copy faces , I need is line ,not face , must add a step "explode" , and I need line position remains the same.:)
Hi AIberto,
the "_xedges" command, allows you to select only the desired edges, by pressing 'Ctrl' as you are selecting.
EDIT: As a demo
(defun c:demo (/ ent_l l_ent p1 p2 ss)
 (setq l_ent (entlast)
       ss    (ssadd)
 (prompt "\nPress \"Ctrl\" to select edges: \n")
 (command "_.xedges")
 (while (> (getvar 'cmdactive) 0)
   (command "\\")
 (setq ent_l (entlast))
 (if (and (not (eq l_ent ent_l))
          (setq p1 (getpoint "\nEnter base point: "))
          (setq p2 (getpoint p1 "\nEnter destination point: "))
     (while (setq l_ent (entnext l_ent))
       (ssadd l_ent ss)
     (command "_.move" ss "" p1 p2)
Henrique
Edited by hmsilva
add code
Hi AIberto,
EDIT: As a demo
Henrique
Hi dear henrique.
Thank you ! this is nice!
but I need keep position .
no need "Enter base point: " & "Enter destination point:" , like this:
(vl-cmdf "_solidedit" "_e" "_c" pause"" "0,0,0" "0,0,0" "_X" "_X")
...no need "Enter base point: " & "Enter destination point:"...
Follow the Henrique's suggestion:
...the "_xedges" command, allows you to select only the desired edges, by pressing 'Ctrl' as you are selecting.
or a change of my first:
(vl-cmdf "_solidedit" "_f" "_c" pause "" "_non" "0,0,0" "_non" "0,0,0" "_X" "_X" "_explode" "_L")
Hi AIberto,
I misunderstood, I thought your goal was:
...my bad!
GP's suggestions should work as you are expecting.
Henrique
Thank! GP , this is my thread need!
Thank for help ! I love you!
Hi AIberto,
...my bad!
Henrique
Hi Henrique .
Thank you ! Your answer gave me another inspiration!
use "ctrl" is beautiful! can you remove "Enter base point "& "Enter destination point" from your post #6 ?
Edited by AIberto
You're welcome, AIberto
You don't need a lsp, just use the 'xedges' command, and the selected edges will be copied to the current layer.
Henrique
Henrique
OK! I know! Thank you! Henrique.
