blintz Posted December 21, 2014 Share Posted December 21, 2014 (edited) hello everyone I have an excel sheet in which the columns are divided in this way A = X axis B = Y axis C = Z axis D = Block Name E = Scale X F = Scale Y G = Z Scale H = rotation angle The button "Insert Blocks" we put blocks in the coordinates , cells (A : C ) I would like to have the possibility of incorporating the TAG block then the column "I" becomes I = Tag1 Code Dim AcadApp As Object Dim AcadDoc As Object Dim acadBlock As Object Dim LastRow As Long Dim i As Long Dim insertionPoint(0 To 2) As Double Dim BlockName As String Dim BlockScale As ScaleFactor Dim RotationAngle As Double 'Activate the coordinates sheet and find the last row. With Sheets("Coordinates") .Activate LastRow = .Cells(.Rows.Count, "A").End(xlUp).Row End With 'Check if there are coordinates for at least one circle. If LastRow < 2 Then MsgBox "There are no coordinates for the insertion point!", vbCritical, "Insertion Point Error" Exit Sub End If 'Check if AutoCAD application is open. If is not opened create a new instance and make it visible. On Error Resume Next Set AcadApp = GetObject(, "AutoCAD.Application") If AcadApp Is Nothing Then Set AcadApp = CreateObject("AutoCAD.Application") AcadApp.Visible = True End If 'Check (again) if there is an AutoCAD object. If AcadApp Is Nothing Then MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error" Exit Sub End If On Error GoTo 0 'If there is no active drawing create a new one. On Error Resume Next Set AcadDoc = AcadApp.ActiveDocument If AcadDoc Is Nothing Then Set AcadDoc = AcadApp.Documents.Add End If On Error GoTo 0 'Check if the active space is paper space and change it to model space. If AcadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding AcadDoc.ActiveSpace = 1 '1 = acModelSpace in early binding End If On Error Resume Next 'Loop through all the rows and add the corresponding blocks in AutoCAD. With Sheets("Coordinates") For i = 2 To LastRow 'Set the block name. BlockName = .Range("D" & i).value 'If the block name is not empty, insert the block. If BlockName <> vbNullString Then 'Set the insertion point. insertionPoint(0) = .Range("A" & i).value insertionPoint(1) = .Range("B" & i).value insertionPoint(2) = .Range("C" & i).value 'Initialize the optional parameters. BlockScale.X = 1 BlockScale.Y = 1 BlockScale.Z = 1 RotationAngle = 0 'Set the optional parameters (if there are values on the corresponding ranges). If .Range("E" & i).value <> vbNullString Then BlockScale.X = .Range("E" & i).value If .Range("F" & i).value <> vbNullString Then BlockScale.Y = .Range("F" & i).value If .Range("G" & i).value <> vbNullString Then BlockScale.Z = .Range("G" & i).value If .Range("H" & i).value <> vbNullString Then RotationAngle = .Range("H" & i).value 'Add the block using the sheet data (insertion point, block name, scale factors and rotation angle). 'The 0.0174532925 is to convert degrees into radians. Set acadBlock = AcadDoc.ModelSpace.InsertBlock(insertionPoint, BlockName, _ BlockScale.X, BlockScale.Y, BlockScale.Z, RotationAngle * 0.0174532925) End If Next i End With 'Zoom in to the drawing area. AcadApp.ZoomExtents 'Release the objects. Set acadBlock = Nothing Set AcadDoc = Nothing Set AcadApp = Nothing 'Inform the user about the process. MsgBox "The blocks were successfully inserted in AutoCAD!", vbInformation, "Finished" End Sub how can I change the code ? greetings gigi Win7 - Autocad electrical 2015 Edited December 21, 2014 by blintz Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 21, 2014 Share Posted December 21, 2014 (edited) This will give tag name If .Range("I" & i).value vbNullString Then RotationAngle = .Range("I" & i).value add block then update attributes using tagname. something like If attribs(x).Tagstring = Tag1 do something you have to step through the attributes (x) checking tagnames. Edited December 22, 2014 by BIGAL tagstring Quote Link to comment Share on other sites More sharing options...
blintz Posted December 22, 2014 Author Share Posted December 22, 2014 thanks for the reply I am very confused I do not know what I have to declare events autocad please can you post an example Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 23, 2014 Share Posted December 23, 2014 This snippet should help Dim attribs As Variant Set SS = ThisDrawing.SelectionSets.Add("pit1sel") SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal For Cntr = 0 To SS.Count - 1 If SS.Item(Cntr).Name = BLOCK_NAME Then attribs = SS.Item(Cntr).GetAttributes ' need a for x loop that equals number of attributes I have not done it before maybe Cntrxmax = attribs.Count if attribs(x).Tagstring = Tag1 then do something Quote Link to comment Share on other sites More sharing options...
blintz Posted December 24, 2014 Author Share Posted December 24, 2014 Bigal thank you for help and advice ps I saw your discussion on this topic with the same values but I think the code is not applicable to what I'm using it crashes all Merry Christmas and thank you ......... Quote Link to comment Share on other sites More sharing options...
witchhero Posted June 6, 2015 Share Posted June 6, 2015 Hi Blintz, Did you complete the code? you can contact with me about the code? I found a similar code.code is working but for simple block. I wanted change for attribute block but I can not do. Can you help? Option Explicit 'A custom type that holds the scale factors of the block. Private Type ScaleFactor X As Double Y As Double Z As Double End Type Sub InsertBlocks() '-------------------------------------------------------------------------------------------------------------------------- 'Inserts blocks in AutoCAD using data - insertion point, block name/full path, scale factors, rotation angle - from Excel. 'Note that the block name or the block path must already exists, otherwise nothing will be inserted. 'The code uses late binding, so no reference to external AutoCAD (type) library is required. 'It goes without saying that AutoCAD must be installed at your computer before running this code. 'Written by: Christos Samaras 'Date: 21/04/2014 'e-mail: xristos.samaras@gmail.com 'site: http://www.myengineeringworld.net '-------------------------------------------------------------------------------------------------------------------------- ' Define the block 'Declaring the necessary variables. Dim acadApp As Object Dim height As Double Dim acadDoc As Object Dim acadBlock As Object Dim attributeObj As Object Dim LastRow As Long Dim i As Long Dim InsertionPoint(0 To 2) As Double Dim BlockName As String Dim BlockScale As ScaleFactor Dim RotationAngle As Double Dim tag As String Dim value As String Dim prompt As String tag = "ATT1" value = Range("E3") height = 250 'Activate the coordinates sheet and find the last row. With Sheets("Coordinates") .Activate LastRow = .Cells(.Rows.Count, "A").End(xlUp).Row End With 'Check if there are coordinates for at least one circle. If LastRow < 2 Then MsgBox "There are no coordinates for the insertion point!", vbCritical, "Insertion Point Error" Exit Sub End If 'Check if AutoCAD application is open. If is not opened create a new instance and make it visible. On Error Resume Next Set acadApp = GetObject(, "AutoCAD.Application") If acadApp Is Nothing Then Set acadApp = CreateObject("AutoCAD.Application") acadApp.Visible = True End If 'Check (again) if there is an AutoCAD object. If acadApp Is Nothing Then MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error" Exit Sub End If On Error GoTo 0 'If there is no active drawing create a new one. On Error Resume Next Set acadDoc = acadApp.ActiveDocument If acadDoc Is Nothing Then Set acadDoc = acadApp.Documents.Add End If On Error GoTo 0 'Check if the active space is paper space and change it to model space. If acadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding acadDoc.ActiveSpace = 1 '1 = acModelSpace in early binding End If On Error Resume Next 'Loop through all the rows and add the corresponding blocks in AutoCAD. With Sheets("Coordinates") For i = 2 To LastRow 'Set the block name. BlockName = .Range("D" & i).value 'If the block name is not empty, insert the block. If BlockName <> vbNullString Then 'Set the insertion point. InsertionPoint(0) = .Range("A" & i).value InsertionPoint(1) = .Range("B" & i).value InsertionPoint(2) = .Range("C" & i).value 'Initialize the optional parameters. BlockScale.X = 1 BlockScale.Y = 1 BlockScale.Z = 1 RotationAngle = 0 'Add the block using the sheet data (insertion point, block name, scale factors and rotation angle). 'The 0.0174532925 is to convert degrees into radians. Set attributeObj = acadBlock.AddAttribute(height, _ prompt, InsertionPoint, tag, value) Set acadBlock = acadDoc.ModelSpace.Insertblock(InsertionPoint, BlockName, _ BlockScale.X, BlockScale.Y, BlockScale.Z, RotationAngle * 0.0174532925) End If Next i End With 'Zoom in to the drawing area. acadApp.ZoomExtents 'Release the objects. Set acadBlock = Nothing Set acadDoc = Nothing Set acadApp = Nothing End Sub Quote Link to comment Share on other sites More sharing options...
