In example i have object named "picket" and i wanna check if there are these pickets then need put in to a list with an entity name. How to do this using vlax-ldata-put. Put these data in to database?
All working function would look like this.. I type command (all_data) in command input and the required data savings in autocad memory, and in the console i can check with command vlax-ldata-list
(defun c:tinklolinija (/ test pradzios_taskas)
 (vl-load-com)
(while
(if (tblsearch "block" "Piketas")
(princ "\nBlock Piketas not found.")
Edited by insane
So is there anyone help ? how to get entity name?
Look up how to use SSGET and filters you can search for blocks named picket.
(setq ss (ssget "X" (list (cons 0 "Insert")(cons 2 "Picket"))))
Edited by BIGAL
I written code that print counted object names in alertbox but it doesnt show entity name.. What i am missing ?
(defun c:bcount ( / p1 b a n obj name)
(setq p1 (getstring "\Name of Block : "))
;get the name of the block
(setq b (cons 2 p1))
;construct a dotted pair - code 2 is for blocks
(setq a (ssget "x" (list b)))
;filter for the block name
(if (/= a nil)
;check if there are any blocks of that name
   ;if there is…
	(setq n (sslength a))
    (setq ent (entlast a))
	;count the number of blocks
	(alert (strcat "\nThere are " (itoa n)  " in the DataBase. Enity: " (itoa ent) ))
	;display the result
   );progn
   ;if there are no blocks
	(alert "\nThere are none in the DataBase")
	;inform the user
);if
in this case The name of block but not one all i need, but now its complicated.. Hmm i need another way how to get block names entity. Is there way to check if exact name of block exists ant ten put ta entity name in to database using vlax-ldata-put ?
Look at my post and replace "Picket" with p1
Also "\Name should be "\nName the \n means new line.
jap I've noticed differences with existing name showing selection set and some numbers, with p1 returns nil
This sample will show you the entity-name and the vla-object-name of a selected object:
(vl-load-com)
(setq entity
      (car
    (entsel "\nSelect Item: ")    ; select item
(if entity                ; check if something selected
 (progn                ; if so, do some stuff
   (princ (strcat "\nEntity is a: "    ; combine some strings
          (vl-princ-to-string (type entity))
                   ; convert type-output to string
   (princ (strcat "\nThe entity name is: "
          (vl-princ-to-string entity)
(princ "\nAnd now VLA-data:")
(setq a-vla-object
      (vlax-ename->vla-object entity)    ; convert a ename to a vla-object
(princ
 (strcat "\nVLA-Entity: " (vl-princ-to-string a-vla-object))
Thats ok i see it get entity name, but for me still need those entity names counting and write in to the database. Without using entsel function i mean automaticaly..when you press function in comman line
(defun c:bcount    (/ A-VLA-OBJECT CNT ENTITY SS)
 (vl-load-com)
 (setq cnt 0)
 (setq ss (ssget "_X" '((0 . "INSERT"))))
 (if ss
     (repeat (sslength ss)
   (setq entity (ssname ss cnt))
   (setq a-vla-object
   (princ
   (setq cnt (1+ cnt))
     (princ (strcat "\nBlocks found: " (itoa cnt)))
(c:bcount)
You may find this usefull: http://www.theswamp.org/index.php?topic=43710.0
well this code a lot warmer, if its possible to choose what name of entity would save ?
Not sure what you mean, do you want only blocks with a specific name?
Change:
To:
(setq ss (ssget "_X"  (list '(0 . "INSERT")
                           [color=blue]'(2 . "YOUR_BLOCKNAME")[/color])))
