Results 1 to 2 of 2
    Forum Newbie
    Map 3D 2012
    Dec 2014
    9
    Default ALIGNSPACE Weirdness
    I have no actual AutoCAD training, so please forgive any made up terms on my part.
    I am attempting to align my paperspace with the viewport in model space. My understanding of viewports is quite limited.
    I select the alignment points in MODEL SPACE (upper right corner, lower left corner), the same points in PAPER SPACE, hit enter, and this happens:
    The origin skews several degrees. What gives?
    This very well may be entirely the wrong way of going about this...
    Any help is very much appreciated.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,705
    Just do a Mview in the layout pick the two corner pts then double click to go into the window then Z E this will show your model space at a zoom extents scale, you then set your plot scale. Ignore the model space two pts step.
    It should be square if you need it rotated there is various ways to do it UCS, View Rotate model. If its skewed then you may have a ucs set go back to modelspace and do UCS S name in layout window UCS R name
  1. VBA/Macro weirdness
    By Mr_Joe in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Jun 2014, 10:08 pm
  2. Visual weirdness
    By KiLLiNG-TiME in forum AutoCAD General
    Last Post: 8th Nov 2012, 11:39 am
  3. CopyMode Weirdness?
    By ILoveMadoka in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Nov 2009, 03:32 pm
  4. Selection weirdness
    By Mr. Gray827 in forum AutoCAD Drawing Management & Output
    Last Post: 21st Dec 2007, 10:20 pm
  5. LDD File Locks & Weirdness
    By CyberAngel in forum Civil 3D & LDD
    Last Post: 27th Nov 2006, 06:26 pm
Tags for this Thread
