Andrew1979 Posted January 12, 2015 Share Posted January 12, 2015 A friend of mine said his boss often opens up drawings as read-only, does some work, then realises he can't save to the file. Of course he could save as and muck around that way but the question was "is there a way to make a pop-up message appear if the drawing is read-only?" So, I put the question towards you clever people out there of how this could be achieved.....if at all. Thanks Quote Link to comment Share on other sites More sharing options...
pBe Posted January 12, 2015 Share Posted January 12, 2015 That is odd, The words "Read-only" appears on the top of the autocad window session as a suffix to the file name. Pop-up message can be achieved with a reactor [save]. command: save [qsave] Reactor checks the drawing status. ReadOnly IF -1 or :vlkax-true then message pops up EDIT: Are you wanting the pop-up message to appear even before the user starts working on the drawing? I'm guessing the a pop-up message is needed if the drawing session is idle for a couple of minutes. is that how you envisioned a program to work? Quote Link to comment Share on other sites More sharing options...
Andrew1979 Posted January 12, 2015 Author Share Posted January 12, 2015 thanks for the info. Yeah his boss isn't that computer savy and misses the basic things by sound of it. Yeah I was hoping that as soon as the program opened a pop would come up if it was read only. One way I thought was to simply assign something to say the line command so as soon as he tried to add anything it would pop up a message. This isn't ideal though as he might just be stretching or moving objects. Quote Link to comment Share on other sites More sharing options...
pBe Posted January 12, 2015 Share Posted January 12, 2015 thanks for the info. Yeah his boss isn't that computer savy and misses the basic things by sound of it. Yeah , a lot them bosses are like that. Yeah I was hoping that as soon as the program opened a pop would come up if it was read only. Strange, Autocad does have that feature, Autocad Alert.... with a big X inside a RED DOT One way I thought was to simply assign something to say the line command so as soon as he tried to add anything it would pop up a message. This isn't ideal though as he might just be stretching or moving objects. If you were to take the Reactor route, i would suggest "Zoom" for command reactor. almost always, a user starts with that. [me thinks] Quote Link to comment Share on other sites More sharing options...
Andrew1979 Posted January 12, 2015 Author Share Posted January 12, 2015 thanks, thats a great idea about the zoom. And yes, I vaguely remember years ago opening an AutoCAd drawing and an alert coming up about read-only....must be a setting somewhere that might turn that off. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 12, 2015 Share Posted January 12, 2015 As a default if you open a dwg that is set to read only or open by someone else a big message appears asking "do you want to continue" ? Does the BOSS just ignore this ? Using a reactor as previously mentioned you could do a saves as adding the boss's login (getenv "username") as the name and auto save. Plus all sorts of other checks ie saves as dwg-boss-2, dwg-boss-3 3rd time opened. Quote Link to comment Share on other sites More sharing options...
Andrew1979 Posted January 12, 2015 Author Share Posted January 12, 2015 well its my friends boss but I have wondered the same. I did notice though that if you open an AutoCAD drawing as read only through AutoCAD no message comes up. So I'm not sure if he is doing that or, as you said, just ignoring the prompt. I think more questions need to be asked to what he is doing and how he is opening drawings to see where the problem lies. It may be a more simple solution to better education of how to go about things. Thanks for the tips on reactor too Quote Link to comment Share on other sites More sharing options...
pBe Posted January 12, 2015 Share Posted January 12, 2015 ...adding the boss's login (getenv "username") as the name and auto save. Plus all sorts of other checks ie saves as dwg-boss-2, dwg-boss-3 3rd time opened. Brilliant idea using the "username" Bigal, for some reasons the Boss does ignore the Autocad Alert warning, and another thing , the notification is somehow disabled [beats me how that happened], So granting all those are true [or a fact], the purpose is to prevent the Bosses from doing anything even before they realized that the file is in Read-only mode via invoking save. I guess the reasoning for this is to avoid creating multiple copies of a drawing file, so saveas is out of the question. Like i said, i'm just guessing Perhaps a dwg-reactor <:vlr-begindwgopen> s enough [granting the alert notification is disabled Quote Link to comment Share on other sites More sharing options...
JamCAD Posted January 12, 2015 Share Posted January 12, 2015 By the way if you have AutoCAD 2014 or later then there should be a lock icon on the drawing tab if it is opened read only. I've attached a screenshot below. If you have an earlier version of AutoCAD you can download the drawing tabs program from the following link: https://apps.exchange.autodesk.com/ACD/Detail/Index?id=adn.exchange.autodesk.com:Drawing-Tabs:en On the other hand I do like where this thread is heading. I wouldn't mind having an routine that will give you an option of saving a copy with your username and date stamp prefix. I've never got around to programming in lisp with reactors before as I haven't had the need/time to learn. However it's interesting me enough to look into it in a bit more depth :-) Quote Link to comment Share on other sites More sharing options...
