mText converting/calculating
Hello @ all,
i am new in this forum, and i hope that anybody can help me with my task:)
i often become dwg-files from our customers. In this files there are many components. All components have an mtext with a length.
here are some examples of which can be in the mtext.
-F 450
-N 380
-1120
-D+B 1120
the problem is that we need other lengths for our production. So i have to change each mtext manually.
for example:
if an mtext contains "F 450" than calculate "450-4" --> F 446
if an mtext contains "N 380" than calculate "380+23" --> N 403
if an mtext contains "1120" than calculate "1120-4" --> 1116
if an mtext contains "D+B 1120" than calculate "1120-4" --> D+B 1116
the letter before the number decides how much is subtracted.
if there is no letter before the number than subtract "-4"
is it possible to create a lisp that can change all selected mtext`s and calculate it to our lengths?
Thanks for your help
Welcome to CADTutor .
have a play with this program and let me know .
(defun c:Test (/ ss)
;;;    Tharwat 17.01.2015    ;;;
 (if (setq ss (ssget "_:L" '((0 . "MTEXT,TEXT") (1 . "F*#,N*#,*#*,D+B*#"))))
   ((lambda (i / sn e st)
      (while (setq sn (ssname ss (setq i (1+ i))))
        (cond
          (    (wcmatch (setq st (cdr (assoc 1 (setq e (entget sn))))) "F*#")
               (setq st (strcat "F " (itoa (- (read (substr st 2)) 4))))
          (    (wcmatch st "N*#") (setq st (strcat "N " (itoa (+ (read (substr st 2)) 23))))
          (    (wcmatch st "D+B*#") (setq st (strcat "D+B " (itoa (- (read (substr st 4)) 4))))
          (    (numberp (read st)) (setq st (itoa (- (read st) 4))))
        (entmod (subst (cons 1 st) (assoc 1 e) e)
     -1
Edited by Tharwat
replaced - with + and thanks to Henrique
@Tharwat,
WOW this is awesome!:D
It works perfect!
Thank you very much, i can`t belive that this works:D:D:D
@Tharwat,
It works perfect!
Ha ha ha ... , you are most welcome . :D
