help with cross section lisp
Hi i need help with a cross section lisp. I use *.txt files with distanse and elevetion to draw the polyline for the ground. I need help to do 2 things
1) draw the table under this polyline with the distanse and the elevetions
2) to add an opltion if i have 2 ground to add
Here is my code to modify.For more details look the example.dwg file and two ground files to do the test.
(Defun c:test ()
(setq g1 (getfiled "select ground1 file  L,H (*.txt)" "" "txt" 16))
(setq fil (open g1 "r"))
(COMMAND "_layer" "_m" "ground1" "_c" "94" "" "")
(COMMAND "_layer" "_m" "line" "_c" "9" "" "") ; The line must be dashdot
(COMMAND "_layer" "_m" "section table" "_c" "7" "" "")
(COMMAND "_layer" "_m" "Datum" "_c" "7" "" "")
(setq scl(/ (getreal  "\n give the scale (100,200,500,etc) : ") 100))
(setq ht(* 0.0018 scl)) ; text size
(setq oflin (* 0.012 scl)) ; offset lines
;I dont know how to add a questio at the begining like this
;If you want to draw ground1 select A / for ground2 select B
;(progn
;	   (initget "A B")
;	   (setq
;	     k
;	      (cond
;		((getkword
;		   "\nFor ground1 (Α)/ For ground2 (Β) < A > :"
;		("A")
; from ground2
;(setq g2 (getfiled "select ground2 file  L,H (*.txt)" "" "txt" 16))
;(setq fil (open g2 "r"))
;(COMMAND "_layer" "_m" "ground2" "_c" "10" "" "")
(command "_.pline"); start Polyline
(while (setq lin (read-line fil)) (command lin)); feed in coordinates
(command ""); end Polyline
(close fil)
; I dont know how to draw the lines
);End Defun
example.dwg
ground1 and ground2.dwg
ground1.txt
ground2.txt
Edited by prodromosm
Hi sanju2323 nice code but i need same chances
1) i use grads so i have problem with the texts rotation
2) change text size by scale
3)An option to choose ground1/ground2
4) in post #1 i ask to choose for ground 1 automaticaly the datum and for the ground 2 to geve manualy the datum
5)Add layer ground1 for ground 1 elevetion and distance and ground 2 for ground2
Thanks
I try to change this but i have a text print problem
(defun ERR (S)
 (if (= S "Function cancelled")
   (princ "\nVERTEXT - cancelled: ")
   (progn (princ "\nVERTEXT - Error: ") (princ S) (terpri))
 (RESETTING)
 (princ "SYSTEM VARIABLES have been reset\n")
(defun SETV (SYSTVAR NEWVAL)
 (setq X (read (strcat SYSTVAR "1")))
 (set X (getvar SYSTVAR))
 (setvar SYSTVAR NEWVAL)
(defun SETTING ()
 (setq OERR *ERROR*)
 (setq *ERROR* ERR)
 (SETV "CMDECHO" 0)
 (SETV "BLIPMODE" 0)
(defun RSETV (SYSTVAR)
 (setvar SYSTVAR (eval X))
(defun RESETTING ()
 (RSETV "CMDECHO")
 (RSETV "BLIPMODE")
 (setq *ERROR* OERR)
(defun DXF (CODE ENAME) (cdr (assoc CODE (entget ENAME)))) ; dxf
(defun VERTEXT (/ EN VLIST)
 (setq EN (GET-EN))
 (if (= (DXF 0 EN) "LWPOLYLINE")
   (setq VLIST (GET-LWVLIST EN))
   (setq VLIST (GET-PLVLIST EN))
 (WRITE-IT VLIST EN)
(defun GET-EN (/ NO-ENT EN MSG1 MSG2)
 (setq	NO-ENT 1
EN     NIL
MSG1   "\nSelect a polyline: "
MSG2   "\nNo polyline selected, try again."
 )					; setq
 (while NO-ENT
   (setq EN (car (entsel MSG1)))
   (if	(and EN
     (or (= (DXF 0 EN) "LWPOLYLINE") (= (DXF 0 EN) "POLYLINE"))
				; or
)				; and
     (progn (setq NO-ENT NIL))		; progn
     (prompt MSG2)
   )					; if
 )					; while
 EN
)					; get-en
(defun GET-LWVLIST (EN / ELIST NUM-VERT VLIST)
 (setq	ELIST	 (entget EN)
NUM-VERT (cdr (assoc 90 ELIST))
ELIST	 (member (assoc 10 ELIST) ELIST)
VLIST	 NIL
 )					; setq
 (repeat NUM-VERT
   (setq VLIST	(append VLIST (list (cdr (assoc 10 ELIST)))) ; append
   )					; setq
   (setq ELIST	(cdr ELIST)
   )					; setq
 )					; repeat
 VLIST
)					; get-lwvlist
(defun GET-PLVLIST (EN / VLIST)
 (setq	VLIST NIL
EN    (entnext EN)
 )					; setq
 (while (/= "SEQEND" (DXF 0 EN))
   (setq VLIST (append VLIST (list (DXF 10 EN))))
   (setq EN (entnext EN))
 )					; while
 VLIST
)					; get-plvlist
(defun WRITE-IT	(VLST EN / NEWVLIST MSG3 FNAME)
 (setq	NEWVLIST (mapcar '(lambda (X) (trans X EN 0)) ;_ lambda
		 VLST
	 ) ;_ mapcar
MSG3	 "Polyline vertex file"
				;FNAME    (getfiled MSG3 "" "txt" 1)
F1	 (open "FNAME" "w")
 )					; setq
 (WRITE-HEADER)
 (WRITE-VERTICES NEWVLIST)
 (setq F1 (close F1))
) ;_ write-it
(defun WRITE-HEADER (/ STR)
 (setq STR "        POLYLINE VERTEX POINTS")
 (write-line STR F1)
 (setq	STR (strcat "  X            " "  Y            " "  Z") ;_ strcat
 ) ;_ setq
 (write-line STR F1)
) ;_ write-header
(defun WRITE-VERTICES (NEWVLIST / XSTR YSTR ZSTR STR)
[color="red"] (COMMAND "_layer" "_m" "ground1" "_c" "94" "" "")
(setq httt (* 0.018 scl))[/color]
 (setq gptx (getpoint "\nBasepoint for X axis: "))
 (setq gpty (getpoint "\nBasepoint for Y axis: "))
 (foreach ITEM	NEWVLIST
   (setq XSTR (rtos (nth 0 ITEM) 2 3)
  YSTR (rtos (nth 1 ITEM) 2 3)
  ZSTR (rtos (nth 2 ITEM) 2 3)
  STR  (strcat XSTR (SPACES XSTR) YSTR (SPACES YSTR) ZSTR) ;_ strcat
   )					; setq
				;      (write-line STR F1)
   (command "text"
     (list (+ (atof xstr) (/ (atof httt) 2.0)) (cadr gptx))
     httt
    [color="red"] "0"[/color]
     (strcat xstr)
   (command "text"
     (list (+ (atof xstr) (/ (atof httt) 2.0)) (cadr gpty))
     httt
     (strcat ystr)
 )					; foreach
)					; write-vertices
(defun SPACES (STR / FIELD NUM CHAR SPACE)
 (setq	FIELD 15
NUM   (- FIELD (strlen STR))
CHAR  " "
SPACE ""
 ) ;_ setq
 (repeat NUM (setq SPACE (strcat SPACE CHAR))) ;_ repeat
) ;_ spaces
(defun C:Test2 () (SETTING) (VERTEXT) (RESETTING) (princ)) ; c:nsl
(prompt "\nEnter Test to start")
I update the code but i have a problem with the scale of the text
(defun ERR (S)
 (RESETTING)
(defun SETTING ()
 (setq OERR *ERROR*)
 (setq *ERROR* ERR)
 (SETV "CMDECHO" 0)
 (SETV "BLIPMODE" 0)
(defun RESETTING ()
 (RSETV "CMDECHO")
 (RSETV "BLIPMODE")
 (setq *ERROR* OERR)
 (setq EN (GET-EN))
 (WRITE-IT VLIST EN)
 (setq	NO-ENT 1
EN     NIL
 )					; setq
 (while NO-ENT
   (if	(and EN
				; or
)				; and
     (prompt MSG2)
   )					; if
 )					; while
 EN
)					; get-en
VLIST	 NIL
 )					; setq
 (repeat NUM-VERT
   )					; setq
   )					; setq
 )					; repeat
 VLIST
)					; get-lwvlist
 (setq	VLIST NIL
EN    (entnext EN)
 )					; setq
 )					; while
 VLIST
)					; get-plvlist
		 VLST
	 ) ;_ mapcar
 )					; setq
 (WRITE-HEADER)
) ;_ write-it
 (write-line STR F1)
 ) ;_ setq
 (write-line STR F1)
) ;_ write-header
   (initget "A B")
   (setq
     k
      (cond
	((getkword
	("A")
(if (eq k "A")
      (if (eq k "B")
[color="red"](setq sk (/ (getreal  "\n give the scale (100,200,500,etc) : ") 100))
(setq httt (* 0.0018 sk))[/color]
   )					; setq
(command "-style" "romans" "wgsimpl.shx" 0 1 0 "N" "N")
   (command "text"
     httt
     "0"
     (strcat xstr)
   (command "text"
     httt
     "0"
     (strcat ystr)
 )					; foreach
)					; write-vertices
 (setq	FIELD 15
CHAR  " "
SPACE ""
 ) ;_ setq
) ;_ spaces
(defun C:Test () (SETTING) (VERTEXT) (RESETTING) (princ)) ; c:nsl
Can any one fix this
to choose for ground 1 automaticaly the datum and for the ground 2 to give manualy the datum
draw parallel lines with ( line offset = 0.012 *scale) and center the text between them like example.dwg ?
Thanks
