I am trying to set up a lisp to change the format of various rawdata , the problem is now I can not write such a long number 1000000452536 and it will write as 1.0e + 012 . is there a way to write numbers in the original format ? Thank precedence .
Please pardon my language :(.
Sorry Bigal , it will provide " 1.000000000000E + 18 " , I have to write " 1000000004546 " as the original . eg " ( SUBSTR ( RTOS ( + 10000000000000000 PNUM ) 2 0 ) 2 16 ) " I need an answer as " 0000000000256489 " . is there any idea?
Please pardon my language .
The double-precision floating-point format (usually referred to as simply a 'double', or in AutoLISP, a 'real') is inherently limited to 15 decimal digits of precision.
Hence, when working with numbers such as you have provided, you will lose any precision after the 15th decimal digit:
[color=red]100000000000000[/color]00
Thanks Lee , I really appreciate it . there are other ways that can be done as VB : FORMAT ( PNUM , " 0000000000000000 " ) ?
If the data remains a string, you could add the two numbers by comparing the strings digit-by-digit, for example, consider the following function:
(defun addstrings ( s1 s2 / foo bar str->lst lst->str )
   (defun foo ( x l )
       (if (< 0 x)
           (if l
               (cons (rem (+ x (car l)) 10) (foo (/ (+ x (car l)) 10) (cdr l)))
               (cons (rem x 10) (foo (/ x 10) l))
           l
   (defun bar ( a b )
       (if a (bar (mapcar '(lambda ( x ) (* x 10)) (cdr a)) (foo (car a) b)) (reverse b))
   (defun str->lst ( s )
       (mapcar '(lambda ( x ) (- x 48)) (reverse (vl-string->list s)))
   (defun lst->str ( l )
       (vl-list->string (mapcar '(lambda ( x ) (+ x 48)) l))
   (lst->str (apply 'bar (mapcar 'str->lst (if (< (strlen s1) (strlen s2)) (list s1 s2) (list s2 s1)))))
Applied to your example:
_$ (addstrings "10000000000256489" "825932628")
"10000000826189117"
Thanks Lee , it was as I expected, I will try to learn from it.:D:D:D
Just a dumb question are you designing the trajectory alignment from you home to the moon in mm ? Awful big number.
Sorry , I tried to convert the machine code as the code below :
*110040+0000000000000012 84..10-0000000000065045 85..10-0000000000058120 86..10+0000000000015502 87..10+0000000000001350 88..10+0000000000001485 79....+0000000000000010
*110041+0000000000000013 21.324+0000000024647210 22.324+0000000008851000 31..00+0000000000093414 51..1.+000000000000+034 87..10+0000000000001350 81..00-0000000000150881 82..00-0000000000094929 83..00+0000000000017512 71....+0000000000000PKT 72....+000000000000000J
*110042+0000000000000137 21.324+0000000025004140 22.324+0000000008844170 31..00+0000000000079145 51..1.+000000000000+034 87..10+0000000000001350 81..00-0000000000139432 82..00-0000000000085091 83..00+0000000000017381 71....+000000000000000J 72....+000000000000000J
*110043+0000000000000138 21.324+0000000024635510 22.324+0000000008855460 31..00+0000000000076505 51..1.+000000000000+034 87..10+0000000000001350 81..00-0000000000135244 82..00-0000000000088502 83..00+0000000000017067 71....+000000000000000J 72....+000000000000000J
*110044+0000000000000139 21.324+0000000033927550 22.324+0000000009506470 31..00+0000000000005234 51..1.+000000000000+034 87..10+0000000000001350 81..00-0000000000066874 82..00-0000000000053238 83..00+0000000000015170 71....+000000000000000J 72....+000000000000000J
*110045+0000000000000140 21.324+0000000025001290 22.324+0000000008859240 31..00+0000000000053360 51..1.+000000000000+034 87..10+0000000000001350 81..00-0000000000115187 82..00-0000000000076346 83..00+0000000000016578 71....+000000000000000J 72....+000000000000000J
*110046+0000000000000141 21.324+0000000025613070 22.324+0000000008834480 31..00+0000000000052312 51..1.+000000000000+034 87..10+0000000000001350 81..00-0000000000115836 82..00-0000000000070578 83..00+0000000000016933 71....+000000000000000J 72....+000000000000000J
*110047+0000000000000142 21.324+0000000026251570 22.324+0000000008844380 31..00+0000000000030960 51..1.+000000000000+034 87..10+0000000000001350 81..00-0000000000095758 82..00-0000000000061964 83..00+0000000000016316 71....+000000000000000J 72....+000000000000000J
*110048+0000000000000143 21.324+0000000025236020 22.324+0000000008901390 31..00+0000000000029009 51..1.+000000000000+034 87..10+0000000000001350 81..00-0000000000092723 82..00-0000000000066793 83..00+0000000000016129 71....+000000000000000J 72....+000000000000000J
My version now you can do something
*110040+12 84..10-000065045 85..10-000058120 86..10+000015502 87..10+000001350 88..10+000001485 79....+10
*110041+13 21.324+024647210 22.324+008851000 31..00+000093414 51..1.+00000+034 87..10+000001350 81..00-000150881 82..00-000094929 83..00+000017512 71....+000000PKT 72....+0J
*110042+000000137 21.324+025004140 22.324+008844170 31..00+000079145 51..1.+00000+034 87..10+000001350 81..00-000139432 82..00-000085091 83..00+000017381 71....+0J 72....+0J
