ybx Posted January 24, 2015 Share Posted January 24, 2015 Hi, dear members I have a code for e-transmitting given below (command "_qsave" "_.-ETRANSMIT" "_CH" "Standard" "_C" "_all") in this code command "_all" is no need to run for every file when it is asking for over writing then it should be run .. There is any possibility to change the code as per this Thanks... Quote Link to comment Share on other sites More sharing options...
ybx Posted February 1, 2015 Author Share Posted February 1, 2015 Hi, dear members I have a code for e-transmitting given below (command "_qsave" "_.-ETRANSMIT" "_CH" "Standard" "_C" "_all") in this code command "_all" is no need to run for every file when it is asking for over writing then it should be run .. There is any possibility to change the code as per this Thanks... Hi I found a code which i think need improve (looking any suggestion) (defun c:Etr () (command "_qsave" "_.-ETRANSMIT" "_CH" "Standard" "_C") (while (> (getvar 'cmdactive) 0) (command "_All") ) (princ) ) Quote Link to comment Share on other sites More sharing options...
hmsilva Posted February 1, 2015 Share Posted February 1, 2015 HiI found a code which i think need improve (looking any suggestion) I'm glad you've found a code... As I have said >>>Here , I can't reproduce this behavior running the code, but I did only test in AC2010 (is the only AC I have is this old laptop...), and I did noticed you are on AC2015, you may try to change the cmdactive test, from 0 to 1 (ordinary command is active), and see if it works as expected... I hope this helps Henrique Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 2, 2015 Share Posted February 2, 2015 Please read the Code Posting Guidelines and edit your post to include the Code in Code Tags. Quote Link to comment Share on other sites More sharing options...
ybx Posted February 3, 2015 Author Share Posted February 3, 2015 I'm glad you've found a code...As I have said >>>Here , I can't reproduce this behavior running the code, but I did only test in AC2010 (is the only AC I have is this old laptop...), and I did noticed you are on AC2015, you may try to change the cmdactive test, from 0 to 1 (ordinary command is active), and see if it works as expected... I hope this helps Henrique Thanks..for ur reply cmdactive 1 is not ok.. I try to change the cmdactive test, from 0 to 32 (working...) Thanks... Quote Link to comment Share on other sites More sharing options...
hmsilva Posted February 3, 2015 Share Posted February 3, 2015 You're welcome, ybx! Glad you have it sorted! Henrique Quote Link to comment Share on other sites More sharing options...
