coordinate in list not found
MJLM
I have a a couple of connected lines in Autocad representing a pipe network. I have a simple lisp routine that parses through all lines and writes in a list all intersections like that
(defun nodes (/ s ent i p a b w k)    ;  creates text labeling on each intersection
 (setq s (ssget "X" '((0 . "LINE"))))
 (setq pl nil)
 (repeat (setq i (sslength s))
(setq ent (entget (ssname s (setq i (1- i)))))
       (setq p (cdr (assoc 10 ent)))
(if (not (member p pl))
		(setq k 0)
		(foreach w pl
			(if (not (equal w p 0.001))
				(setq k (1+ k))
		(if (= k (length pl))
			(setq pl (append pl (list p)))
       (setq p (cdr (assoc 11 ent)))
		(setq k 0)
		(foreach w pl
				(setq k (1+ k))
Using this list I want to number these nodes for the lines connected like that
So parsing through each line I have:
(setq pt10 (assoc 10 lineprop))
(setq pt11 (assoc 11 lineprop))
(setq node1 (itoa (1+ (vl-position (cdr pt10) pl))))
(setq node2 (itoa (1+ (vl-position (cdr pt11) pl))))
Here comes my problem. For some reason a point (coordinate) in the pl list is not recognized and gives error that it can not find the (cdr ptxx) in the pl list although apparently it is the same.
I tried to type manually also
!pl
returns: ((0.0 0.0 0.09) (5.0 0.0 0.0) ... (3.0 4.0 5.0) ... (7.0 6.0 6.0) (10.0 6.0 6.0))
(member '(3.0 4.0 5.0) pl)
returns: nil
I understand that the (3.0 4.0 5.0) is not 100% identical with the point in the list. But how can I correct this problem?
Any help would be appreciated.
You need to check with every list of coordinates of the list with a fuzz factor .
eg.
(setq o    (car (entsel "\n Select line :"))
     pt10 (assoc 11 (entget o))
(setq i 0)
(vl-position
 nil
 (mapcar '(lambda (q)
            (if (not (equal (cdr pt10) q 1e-)
              (setq i (1+ i))))
         pl)
Where the variable " i " represents the location of that list of coordinate in the list pl since you are looking for that ,otherwise remove it if you don't want it .
