My department uses an AutoCAD profile that is primarily 2D drafting. Other departments use a full Civil 3D AutoCAD profile with more bells and whistles. I have a list of items that I want to add to our department's profile. How is this done? Can I do it through the customization panel or not?
Thanks!
In simple terms using the Cui and Config you can set all the parmeters you want and then save a new profile and export so as to inport on other machines, you make a copy of the desktop icon and in the properties change the end bit acad.exe...../p mynewprofile.
The other way is have you looked at using workspaces adding a new one, Bottom left little gear wheel all of our guys&gal have their name so when something realaly goes wrong we can revert back to default and fix, again play with CUI. Its been a while but you need to save your settings as a new CUIX put it somewhere on say each pc, in CONFIG Customization files, main customization file, yourcuix.
I can assure you my workspace menu has stuff from CIV3d and Autocad in one saves jumping across menu's.
Here is a freebie two civ3d menus now in one, meaning I can add an extra menu item just menuload in your Autocad session.
***MENUGROUP=SURFAL
***POP15
**SURFALIGN
[surfalign]
[sURFACES]
ID_XLS_0483 [Create Surface]^c^c_AeccCreateSurface
[Create Surface from DEM]^c^c_AeccCreateSurfaceGridFromDEM
[Create Surface from TIN]^c^c_AeccCreateSurfaceFromTIN
[->Edit Surface]
[Edit Surface Style...]^c^c_AeccEditSurfaceStyle
[Edit Surface Properties]^c^c_AeccEditSurfaceProperties
[Add Line]^C^C_AeccAddSurfaceLine
[Delete Line]^c^c_AeccDeleteSurfaceLine
[swap Edge]^c^c_AeccEditSurfaceSwapEdge
[Add Point]^c^c_AddPointToSurface
[Delete Point]^c^c_AeccDeleteSurfacePoint
[Modify Point]^c^c_AeccEditSurfacePoint
[Move Point]^C^C_AeccMoveSurfacePoint
[Minimize Flat Areas]^c^c_AeccMinimizeSurfaceFlatAreas
[Raise/Lower Surface]^c^c_AeccRaiseLowerSurface
[Paste Surface...]^c^c_AeccEditSurfacePaste
[Add Boundaries]^c^c_AeccAddSurfaceBoundaries
[smooth Surface]^c^c_AeccSmoothSurface
[<-Simplify Surface]^c^c_AeccSimplifySurface
[->Add Surface Labels]^c^c_AeccAddSurfaceLabels
[Add slope Surf Labels]^c^c_AeccAddSurfaceSlopeLabel
[spot Elevation]^c^c_AeccAddSurfaceSpotElevLabel
[spot Elevations on Grid]^c^c_AeccAddSpotElevLabelsOnGrid
[Contour - Single]^c^c_AeccAddContourLabelingSingle
[Contour - Multiple]^c^c_AeccAddContourLabeling
[Contour Multiple at Interval]^c^c_AeccAddContourLabelingGroup
[<-Add legend table]^c^_AeccAddSurfaceLegendTable
[->Utilities]
[Export to DEM]^c^c_AeccSurfaceExportToDem
[Volumes Dashboard]^C^C_AeccVolumesDashboard
[Water Drop...]^c^c_AeccCreateSurfaceWaterDrop
[Catchment Area]^c^c_AeccCatchmentArea
[Check for Contour Problems]^c^c_AeccCheckForContourProblems
[Drape Image]^c^c_AeccDrapeImage
[Extract Objects From Surface]^c^c_AeccSurfaceExtractObjects
[Move Blocks to Surface]^c^c_AeccMoveBlocksToSurface
[Move Blocks to Attribute Elevation]^c^c_AeccMOVEBLOCKSTOATTRIBELEV
[<-Move Text to Elevation]^c^c_AeccMoveTextToElevation
[ALIGNMENTS]
[Create Alignment by Layout]^c^c_AeccCreateAlignmentLayout
[Create Alignment from Polyline]^c^c_AeccCreateAlignmentEntities
[Edit Alignment Geometry]^C^C^p_AeccEditAlignment
[Reverse Alignment Direction]^c^c_AeccReverseAlignDirection
[Design Criteria Editor]^C^c_AeccDesignCriteriaEditor
[Offset lines]^c^cOffsetfeature
[->Add Alignment Labels]^c^c_AeccAddAlignLabels
[Add/Edit Station Labels]^c^c_AeccEditAlignmentLabels
[station/Offset]^c^c_AeccAddAlignOffXYLbl
[single Segment]^c^c_AeccAddAlignSegLbl
[Multiple Segment]^c^c_AeccAddAlignSegLbls
[Point of Intersection]^c^c_AeccAddAlignPointOfIntLbl
[<-Multiple Point of Intersection]^c^c_AeccAddAlignPointOfIntLbls
[->Add Tables]
[Add Line...]^c^c_AeccAddAlignmentLineTable
[Add Curve...]^c^c_AeccAddAlignmentCurveTable
[Add Spiral...]^c^c_AeccAddAlignmentSpiralTable
[Add Segments]^c^c_AeccAddAlignmentSegmentTable
[<-Renumber Tags]^c^c_AeccEditTagNumbers
[POINTS]
[Create pts]^c^c_AeccCreatePoints
[Add 1 PT]^C^C_AeccCreatePointManual
[Pt on Surface]^C^C_AeccCreatePointRandomPoints
[Add PT Table]^C^C_AeccAddPointTable
