xinmh Posted February 6, 2015 Share Posted February 6, 2015 Dear all, Do you have a lisp to labelling horizontal line or vertical line coordinate, just the line's Northing or Easting coordinate parallel to line ,it can be above ,under or on line, can chose location. and can labelling several lines one time. thanks a lot. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 6, 2015 Share Posted February 6, 2015 I moved your thread to the AutoLISP, Visual LISP & DCL Forum. Quote Link to comment Share on other sites More sharing options...
xinmh Posted February 7, 2015 Author Share Posted February 7, 2015 thanks SLW210 Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted February 9, 2015 Share Posted February 9, 2015 (edited) thanks SLW210 Tips: command: _dimordinate also can prefix "N=" or "E=" , but it only shows positive value Updated v1.1: works with LWPOLYLINE & POLYLINE 10.02.2015 http://www.cadtutor.net/forum/showthread.php?90807-labelling-horizontal-line-or-vertical-line-coordinate-parallel-to-line&p=621946#post621946 ;; Make Angle Readable ;credit to ymg (defun MakeReadable (a) (setq a (rem (+ a pi pi) (+ pi pi))) (rem (if (< (* pi 0.5) a (* pi 1.5)) (+ a pi) a ) ;_ end of if (+ pi pi) ) ;_ end of rem ) ;_ end of defun [color="red"];v1.1: works with LWPOLYLINE & POLYLINE[/color] (defun c:test (/ _text ss 2p e lst split glc l) ;hanhphuc 09.02.2015 ;label Vertical & Horizontal Grid (WCS) (defun _text (tx lst / txsize rot pt) (setq txsize (getvar 'textsize) rot (MakeReadable (apply 'angle lst)) pt (polar (apply 'mapcar (cons ''((a b) (* 0.5 (+ a b))) lst)) (+ rot (/ pi 2.)) (* txsize 3.0) ) ;_ end of polar ) ;_ end of setq (entmake (list '(0 . "TEXT") '(72 . 1) ; justify (cons 1 tx) (cons 10 pt) (cons 11 pt) ; justify (cons 40 txsize) (cons 50 rot) ) ; list ) ;_ end of entmake ) ;_ end of defun (defun split (lst len / l ls) (while lst (repeat len (setq l (cons (car lst) l) lst (cdr lst))) (setq ls (cons (reverse l ) ls) l nil) ) (vl-remove-if ''((x)(vl-some 'not x)) (reverse ls)) ) (defun glc (e / obj l cor) ; get *lines coordinates ;hanhphuc 2014 (setq obj (vlax-ename->vla-object e)) (foreach p '("Coordinates" "EndPoint" "StartPoint") (if (vlax-property-available-p obj p) (setq l (cons p l)) ) ;_ end of if ) ;_ end of foreach (setq cor (mapcar ''((p) (vlax-get obj p)) l)) (eval (cons 'cond (reverse (vl-list* '(t cor) (mapcar ''((a b) (list (list '= (cdr (assoc 0 (entget e))) a) (cons 'quote (list (split (car cor) b))) ) ) '("LWPOLYLINE" "POLYLINE" ) '(2 3) ) ;_ end of mapcar ) ;_ end of vl-list* ) ;_ end of reverse ) ;_ end of cons ) ;_ end of eval ) ;_ end of defun (prompt "\nSelect grid lines.. ") (setq ss (ssget ":L" '((0 . "*LINE")))) (repeat (sslength ss) (setq lst (glc (setq e (ssname ss 0)))) (foreach 2p (mapcar ''((a b) (list a b)) lst (cdr lst)) (eval (cons 'cond (mapcar '(lambda (a b) (list (equal (car (setq l (mapcar a 2p))) (cadr l) 1.0e- (cons '_text (list (strcat b (rtos (car l) 2 3)) '2p)) ) ;_ end of list ) ;_ end of lambda '(car cadr) '("E= " "N= ") ; or '("X= " "Y= ") ) ;_ end of mapcar ) ;_ end of cons ) ;_ end of eval (princ) ) ;_ end of foreach (ssdel e ss) ) ;_ end of repeat (princ) ) ;_ end of defun HTH Edited February 10, 2015 by hanhphuc now user can label on polyline as requested Quote Link to comment Share on other sites More sharing options...
xinmh Posted February 10, 2015 Author Share Posted February 10, 2015 thanks a lot!!!! @hanhphuc ,I have test the lisp,it work very nice for "line",but it can not labelling the "ployline""3dpoly",could you please add the function to it, thanks a bunch.... Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted February 10, 2015 Share Posted February 10, 2015 thanks a lot!!!!@hanhphuc ,I have test the lisp,it work very nice for "line",but it can not labelling the "ployline""3dpoly",could you please add the function to it, thanks a bunch.... you are welcome xinmh updated post#4 Quote Link to comment Share on other sites More sharing options...
xinmh Posted February 11, 2015 Author Share Posted February 11, 2015 you are welcome xinmhupdated post#4 perfect!! thanks a lot!!! you are so warmheart!!! Quote Link to comment Share on other sites More sharing options...
CADWORKER Posted October 2, 2019 Share Posted October 2, 2019 On 2/9/2015 at 1:18 PM, hanhphuc said: Tips: command: _dimordinate also can prefix "N=" or "E=" , but it only shows positive value Updated v1.1: works with LWPOLYLINE & POLYLINE 10.02.2015 http://www.cadtutor.net/forum/showthread.php?90807-labelling-horizontal-line-or-vertical-line-coordinate-parallel-to-line&p=621946#post621946 ;; Make Angle Readable ;credit to ymg (defun MakeReadable (a) (setq a (rem (+ a pi pi) (+ pi pi))) (rem (if (< (* pi 0.5) a (* pi 1.5)) (+ a pi) a ) ;_ end of if (+ pi pi) ) ;_ end of rem ) ;_ end of defun [color="red"];v1.1: works with LWPOLYLINE & POLYLINE[/color] (defun c:test (/ _text ss 2p e lst split glc l) ;hanhphuc 09.02.2015 ;label Vertical & Horizontal Grid (WCS) (defun _text (tx lst / txsize rot pt) (setq txsize (getvar 'textsize) rot (MakeReadable (apply 'angle lst)) pt (polar (apply 'mapcar (cons ''((a b) (* 0.5 (+ a b))) lst)) (+ rot (/ pi 2.)) (* txsize 3.0) ) ;_ end of polar ) ;_ end of setq (entmake (list '(0 . "TEXT") '(72 . 1) ; justify (cons 1 tx) (cons 10 pt) (cons 11 pt) ; justify (cons 40 txsize) (cons 50 rot) ) ; list ) ;_ end of entmake ) ;_ end of defun (defun split (lst len / l ls) (while lst (repeat len (setq l (cons (car lst) l) lst (cdr lst))) (setq ls (cons (reverse l ) ls) l nil) ) (vl-remove-if ''((x)(vl-some 'not x)) (reverse ls)) ) (defun glc (e / obj l cor) ; get *lines coordinates ;hanhphuc 2014 (setq obj (vlax-ename->vla-object e)) (foreach p '("Coordinates" "EndPoint" "StartPoint") (if (vlax-property-available-p obj p) (setq l (cons p l)) ) ;_ end of if ) ;_ end of foreach (setq cor (mapcar ''((p) (vlax-get obj p)) l)) (eval (cons 'cond (reverse (vl-list* '(t cor) (mapcar ''((a b) (list (list '= (cdr (assoc 0 (entget e))) a) (cons 'quote (list (split (car cor) b))) ) ) '("LWPOLYLINE" "POLYLINE" ) '(2 3) ) ;_ end of mapcar ) ;_ end of vl-list* ) ;_ end of reverse ) ;_ end of cons ) ;_ end of eval ) ;_ end of defun (prompt "\nSelect grid lines.. ") (setq ss (ssget ":L" '((0 . "*LINE")))) (repeat (sslength ss) (setq lst (glc (setq e (ssname ss 0)))) (foreach 2p (mapcar ''((a b) (list a b)) lst (cdr lst)) (eval (cons 'cond (mapcar '(lambda (a b) (list (equal (car (setq l (mapcar a 2p))) (cadr l) 1.0e- (cons '_text (list (strcat b (rtos (car l) 2 3)) '2p)) ) ;_ end of list ) ;_ end of lambda '(car cadr) '("E= " "N= ") ; or '("X= " "Y= ") ) ;_ end of mapcar ) ;_ end of cons ) ;_ end of eval (princ) ) ;_ end of foreach (ssdel e ss) ) ;_ end of repeat (princ) ) ;_ end of defun hi Hanhphuc; just used your code and its giving me a message error: malformed list on input. Could you please help me HTH Quote Link to comment Share on other sites More sharing options...
dlanorh Posted October 2, 2019 Share Posted October 2, 2019 (edited) 7 hours ago, CADWORKER said: Find this line (equal (car (setq l (mapcar a 2p))) (cadr l) 1.0e- it is missing the final integer and the closing brace The brace is easy but the final integer (8) is a guess as this was an error that occured when the system software was upgraded. See reason for edit (equal (car (setq l (mapcar a 2p))) (cadr l) 1.0e-8) Edited October 2, 2019 by dlanorh Reminded by LeeMac of system upgrade problem 1 Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted October 16, 2019 Share Posted October 16, 2019 (edited) On 10/3/2019 at 4:43 AM, dlanorh said: Find this line (equal (car (setq l (mapcar a 2p))) (cadr l) 1.0e- it is missing the final integer and the closing brace Thanks dlanorh, it was mentioned which 8 ) became smiley was automatic removed in the code tags by the system. p/s quite long time inactive Edited October 16, 2019 by hanhphuc Quote Link to comment Share on other sites More sharing options...
