Is there a way to repeat more than the max number of arguments?
TroyBurr
The code for it is very long. It creates a radial platform from data entered in an excel file. The image file is what it creates. If you really want I can try to post it.
If you post all then everyone will get the code and it looks pretty impressive something a company would not necessarily want others having.
Use vlide and run from there, in DEBUG look at Last Break source so can pin point where it stops then post this bit of code, others like Lee-mac can help better than me with vlide. Also you can Inspect variables looking at values above the point it stops.
