rengised Posted February 14, 2015 Posted February 14, 2015 Hello guys, i need help regarding my autocad problem. everytime I open a drawing theres a text appears in the command line. see text appear below I copied from the coomand line. Thank you. ;;; language command call (e.g. with the leading underscore ;;; mechanism.) (if (not (= (substr (ver) 1 11) "Visual LISP")) (load "acad2006doc.lsp")) ;; Silent load. (princ) ; MODULE_ID ACAD2006_LSP_ ;;; ACAD2006.LSP Version 1.0 for AutoCAD 2006 ;;; ;;; Copyright © 1994-2005 by Autodesk, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE ;;; UNINTERRUPTED OR ERROR FREE. ;;; ;;; Use, duplication, or disclosure by the U.S. Government is subject to ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer ;;; Software - Restricted Rights) and DFAR 252.227-7013©(1)(ii) ;;; (Rights in Technical Data and Computer Software), as applicable. ;;; ;;;. ;;; ;;; Note: ;;; This file is normally loaded only once per AutoCAD session. ;;; If you wish to have LISP code loaded into every document, ;;; you should add your code to acaddoc.lsp. ;;; ;;; Globalization Note: ;;; We do not support autoloading applications by the native ;;; language command call (e.g. with the leading underscore ;;; mechanism.) (if (not (= (substr (ver) 1 11) "Visual LISP")) (load "acad2006doc.lsp")) ;; Silent load. (princ) ; MODULE_ID ACAD2006_LSP_ ;;; ACAD2006.LSP Version 1.0 for AutoCAD 2006 ;;; ;;; Copyright © 1994-2005 by Autodesk, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE ;;; UNINTERRUPTED OR ERROR FREE. ;;; ;;; Use, duplication, or disclosure by the U.S. Government is subject to ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer ;;; Software - Restricted Rights) and DFAR 252.227-7013©(1)(ii) ;;; (Rights in Technical Data and Computer Software), as applicable. ;;; ;;;. ;;; ;;; Note: ;;; This file is normally loaded only once per AutoCAD session. ;;; If you wish to have LISP code loaded into every document, ;;; you should add your code to acaddoc.lsp. ;;; ;;; Globalization Note: ;;; We do not support autoloading applications by the native ;;; language command call (e.g. with the leading underscore ;;; mechanism.) (if (not (= (substr (ver) 1 11) "Visual LISP")) (load "acad2006doc.lsp")) ;; Silent load. (princ) ; MODULE_ID ACAD2006_LSP_ ;;; ACAD2006.LSP Version 1.0 for AutoCAD 2006 ;;; ;;; Copyright © 1994-2005 by Autodesk, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE ;;; UNINTERRUPTED OR ERROR FREE. ;;; ;;; Use, duplication, or disclosure by the U.S. Government is subject to ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer ;;; Software - Restricted Rights) and DFAR 252.227-7013©(1)(ii) ;;; (Rights in Technical Data and Computer Software), as applicable. ;;; ;;;. ;;; ;;; Note: ;;; This file is normally loaded only once per AutoCAD session. ;;; If you wish to have LISP code loaded into every document, ;;; you should add your code to acaddoc.lsp. ;;; ;;; Globalization Note: ;;; We do not support autoloading applications by the native ;;; language command call (e.g. with the leading underscore ;;; mechanism.) (if (not (= (substr (ver) 1 11) "Visual LISP")) (load "acad2006doc.lsp")) ;; Silent load. (princ) ; MODULE_ID ACAD2006_LSP_ ;;; ACAD2006.LSP Version 1.0 for AutoCAD 2006 ;;; ;;; Copyright © 1994-2005 by Autodesk, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE ;;; UNINTERRUPTED OR ERROR FREE. ;;; ;;; Use, duplication, or disclosure by the U.S. Government is subject to ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer ;;; Software - Restricted Rights) and DFAR 252.227-7013©(1)(ii) ;;; (Rights in Technical Data and Computer Software), as applicable. ;;; ;;;. ;;; ;;; Note: ;;; This file is normally loaded only once per AutoCAD session. ;;; If you wish to have LISP code loaded into every document, ;;; you should add your code to acaddoc.lsp. ;;; ;;; Globalization Note: ;;; We do not support autoloading applications by the native ;;; language command call (e.g. with the leading underscore ;;; mechanism.) (if (not (= (substr (ver) 1 11) "Visual LISP")) (load "acad2006doc.lsp")) ;; Silent load. (princ) ; MODULE_ID ACAD2006_LSP_ ;;; ACAD2006.LSP Version 1.0 for AutoCAD 2006 ;;; ;;; Copyright © 1994-2005 by Autodesk, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE ;;; UNINTERRUPTED OR ERROR FREE. ;;; ;;; Use, duplication, or disclosure by the U.S. Government is subject to ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer ;;; Software - Restricted Rights) and DFAR 252.227-7013©(1)(ii) ;;; (Rights in Technical Data and Computer Software), as applicable. ;;; ;;;. ;;; ;;; Note: ;;; This file is normally loaded only once per AutoCAD session. ;;; If you wish to have LISP code loaded into every document, ;;; you should add your code to acaddoc.lsp. ;;; ;;; Globalization Note: ;;; We do not support autoloading applications by the native ;;; language command call (e.g. with the leading underscore ;;; mechanism.) (if (not (= (substr (ver) 1 11) "Visual LISP")) (load "acad2006doc.lsp")) ;; Silent load. (princ) ; MODULE_ID ACAD2006_LSP_ ;;; ACAD2006.LSP Version 1.0 for AutoCAD 2006 ;;; ;;; Copyright © 1994-2005 by Autodesk, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE ;;; UNINTERRUPTED OR ERROR FREE. ;;; ;;; Use, duplication, or disclosure by the U.S. Government is subject to ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer ;;; Software - Restricted Rights) and DFAR 252.227-7013©(1)(ii) ;;; (Rights in Technical Data and Computer Software), as applicable. ;;; ;;;. ;;; ;;; Note: ;;; This file is normally loaded only once per AutoCAD session. ;;; If you wish to have LISP code loaded into every document, ;;; you should add your code to acaddoc.lsp. ;;; ;;; Globalization Note: ;;; We do not support autoloading applications by the native ;;; language command call (e.g. with the leading underscore ;;; mechanism.) (if (not (= (substr (ver) 1 11) "Visual LISP")) (load "acad2006doc.lsp")) ;; Silent load. (princ) ; MODULE_ID ACAD2006_LSP_ ;;; ACAD2006.LSP Version 1.0 for AutoCAD 2006 ;;; ;;; Copyright © 1994-2005 by Autodesk, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE ;;; UNINTERRUPTED OR ERROR FREE. ;;; ;;; Use, duplication, or disclosure by the U.S. Government is subject to ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer ;;; Software - Restricted Rights) and DFAR 252.227-7013©(1)(ii) ;;; (Rights in Technical Data and Computer Software), as applicable. ;;; ;;;. ;;; ;;; Note: ;;; This file is normally loaded only once per AutoCAD session. ;;; If you wish to have LISP code loaded into every document, ;;; you should add your code to acaddoc.lsp. ;;; ;;; Globalization Note: ;;; We do not support autoloading applications by the native ;;; language command call (e.g. with the leading underscore ;;; mechanism.) (if (not (= (substr (ver) 1 11) "Visual LISP")) (load "acad2006doc.lsp")) ;; Silent load. (princ) ; MODULE_ID ACAD2006_LSP_ ;;; ACAD2006.LSP Version 1.0 for AutoCAD 2006 ;;; ;;; Copyright © 1994-2005 by Autodesk, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE ;;; UNINTERRUPTED OR ERROR FREE. ;;; ;;; Use, duplication, or disclosure by the U.S. Government is subject to ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer ;;; Software - Restricted Rights) and DFAR 252.227-7013©(1)(ii) ;;; (Rights in Technical Data and Computer Software), as applicable. ;;; ;;;. ;;; ;;; Note: ;;; This file is normally loaded only once per AutoCAD session. ;;; If you wish to have LISP code loaded into every document, ;;; you should add your code to acaddoc.lsp. ;;; ;;; Globalization Note: ;;; We do not support autoloading applications by the native ;;; language command call (e.g. with the leading underscore ;;; mechanism.) (if (not (= (substr (ver) 1 11) "Visual LISP")) (load "acad2006doc.lsp")) ;; Silent load. (princ) ; MODULE_ID ACAD2006_LSP_ ;;; ACAD2006.LSP Version 1.0 for AutoCAD 2006 ;;; ;;; Copyright © 1994-2005 by Autodesk, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE ;;; UNINTERRUPTED OR ERROR FREE. ;;; ;;; Use, duplication, or disclosure by the U.S. Government is subject to ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer ;;; Software - Restricted Rights) and DFAR 252.227-7013©(1)(ii) ;;; (Rights in Technical Data and Computer Software), as applicable. ;;; ;;;. ;;; ;;; Note: ;;; This file is normally loaded only once per AutoCAD session. ;;; If you wish to have LISP code loaded into every document, ;;; you should add your code to acaddoc.lsp. ;;; ;;; Globalization Note: ;;; We do not support autoloading applications by the native ;;; language command call (e.g. with the leading underscore ;;; mechanism.) (if (not (= (substr (ver) 1 11) "Visual LISP")) (load "acad2006doc.lsp")) ;; Silent load. (princ) ; MODULE_ID ACAD2006_LSP_ ;;; ACAD2006.LSP Version 1.0 for AutoCAD 2006 ;;; ;;; Copyright © 1994-2005 by Autodesk, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ; error: bad argument type: streamp nil Quote
ReMark Posted February 15, 2015 Posted February 15, 2015 Could it be that acad2006.lsp is being loaded automatically upon startup? Are you experiencing any other problems? Quote
nestly Posted February 15, 2015 Posted February 15, 2015 My understanding is that acadxxxx.lsp (and the disclaimer) is a required file that loads for everyone during startup, which in turn loads another required file (acadxxxxdoc.lsp) Neither of these files should be tampered with by the user. I would find acad2006.lsp in C:\Program Files\Autodesk\AutoCAD 2006 and check to see if file has been modified recently (the modified date should be ~ 2005-2006) Quote
ReMark Posted February 15, 2015 Posted February 15, 2015 I'm curious as to the repetitive nature of the message. Virus perhaps? Quote
