georgi9909 Posted February 15, 2015 Posted February 15, 2015 Hi peoples, For a long time I'm searching for way to improve my work speed in Autocad.All functions I've use like line,circle,trim,extend and etc. are with key combination. Things also I want to do are: 1. Loading company layers with key combination 2. Quickly switch to another layer with key combination 3. Quickly change layer of selected object with key combination 4. Quickly switch to another text, dimension and multileader style Can you help me with these things. Thank you in advance! Georgi Quote
ReMark Posted February 15, 2015 Posted February 15, 2015 Shouldn't company layers already be included in your template file? Re: key combinations. Why do these have to be done using lisp? Why not use keyboard shortcuts? Quote
georgi9909 Posted February 15, 2015 Author Posted February 15, 2015 I have template file with company layers, but when I receive drawing from investor or another department I must add our layers. Quote
georgi9909 Posted February 15, 2015 Author Posted February 15, 2015 I know this but will be faster with keyboard shortcut and loading all layers automatic. Quote
ReMark Posted February 15, 2015 Posted February 15, 2015 I'm sure if you look hard enough you'll find someone has already written a lisp that accomplishes the task. You would only have to modify it for your specific layers. What will you do with all the time saved? There are any number of websites that have custom lisp routines available. The Swamp, Cadalyst magazine, Lee Mac's, DoftSoft, ManuSoft, and AfraLISP just to name a few. Quote
georgi9909 Posted February 15, 2015 Author Posted February 15, 2015 Thanks I found lisp for loading layers, but i don't know how to change layers and styles with keyboard. Sorry for rookie questions. Quote
georgi9909 Posted February 15, 2015 Author Posted February 15, 2015 Is it possible to make some lisp which when type: set - to chose what option you want to change Layer/Dim Style/Text Style/Multileader Style/ in Layer will be company layers in Dim Style will be styles you make and etc. Quote
BIGAL Posted February 15, 2015 Posted February 15, 2015 Have a look at a script all you need to do is write down what your doing manually make new layers change text styles etc very simple just do in notepad. -layer n layer1 c layer1 45 n layer211 c layer211 30 Lt dashed textstyle standard The other thing to look at is a custom menu or toolbar that has your company stuff in it, click a button text style set, layer set. Quote
georgi9909 Posted February 16, 2015 Author Posted February 16, 2015 This is the lisp what I'm using for creating the layers. (defun MakeLayer ( name colour linetype lineweight willplot bitflag description ) ;; © Lee Mac 2010 (or (tblsearch "LAYER" name) (entmake (append (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 name) (cons 70 bitflag) (cons 290 (if willplot 1 0)) (cons 6 (if (and linetype (tblsearch "LTYPE" linetype)) linetype "CONTINUOUS" ) ) (cons 62 (if (and colour (< 0 (abs colour) 256)) colour 7)) (cons 370 (if (minusp lineweight) -3 (fix (* 100 (if (and lineweight (<= 0.0 lineweight 2.11)) lineweight 0.0) ) ) ) ) ) (if description (list (list -3 (list "AcAecLayerStandard" (cons 1000 "") (cons 1000 description)) ) ) ) ) ) ) ) (defun c:XT nil (vl-load-com) ;; © Lee Mac 2010 ;; Specifications: ;; Description Data Type Remarks ;; ----------------------------------------------------------------- ;; Layer Name STRING Only standard chars allowed ;; Layer Colour INTEGER may be nil, -ve for Layer Off, Colour < 256 ;; Layer Linetype STRING may be nil, If not loaded, CONTINUOUS. ;; Layer Lineweight REAL may be nil, negative=Default, otherwise 0 <= x <= 2.11 ;; Plot? BOOLEAN T = Plot Layer, nil otherwise ;; Bit Flag INTEGER 0=None, 1=Frozen, 2=Frozen in VP, 4=Locked ;; Description STRING may be nil for no description ;; Function will return list detailing whether layer creation is successful. ( (lambda ( lst / lts ) (setq lts (vla-get-Linetypes (vla-get-ActiveDocument (vlax-get-acad-object)))) (mapcar 'cons (mapcar 'car lst) (mapcar (function (lambda ( x ) (and (caddr x) (or (tblsearch "LTYPE" (caddr x)) (vl-catch-all-apply 'vla-load (list lts (caddr x) "acad.lin")) ) ) (apply 'MakeLayer x) ) ) lst ) ) ) '( ; Name Colour Linetype Lineweight Plot? Bitflag Description ( "Layer1" 5 "CONTINUOUS" 0.50 T 0 nil ) ( "Layer2" 6 "ACAD_ISO04W100" 0.18 T 0 nil ) ( "Layer3" 7 "CONTINUOUS" 0.35 T 0 nil ) ( "Layer4" 40 "CONTINUOUS" 0.35 T 0 nil ) ( "Layer5" 4 "DASHEDx2" 0.18 T 0 nil ) ( "Layer6" 3 "CONTINUOUS" 0.15 T 0 nil ) ( "Layer7" 11 "CONTINUOUS" 0.15 T 0 nil ) ( "Layer8" 2 "CONTINUOUS" 0.35 T 0 nil ) ( "Layer9" 1 "CONTINUOUS" 0.20 T 0 nil ) ) ) ) and this is to changing the layers (defun _SetCLayer (layerName) (if (tblsearch "layer" layerName) (setvar 'clayer layerName) (prompt (strcat "\n** Layer \"" layerName "\" not found ** ") ) ) (princ) ) (defun c:1 () (_SetCLayer "Layer1")) (defun c:2 () (_SetCLayer "Layer2")) (defun c:3 () (_SetCLayer "Layer3")) (defun c:4 () (_SetCLayer "Layer4")) (defun c:5 () (_SetCLayer "Layer5")) (defun c:6 () (_SetCLayer "Layer6")) (defun c:7 () (_SetCLayer "Layer7")) (defun c:8 () (_SetCLayer "Layer8")) (defun c:9 () (_SetCLayer "Layer9")) Quote
georgi9909 Posted February 17, 2015 Author Posted February 17, 2015 How can make similar code for changing layers but I want when select a object to pres 1 or 2 or 3 etc. and selected object to change in this layer. Quote
BIGAL Posted February 18, 2015 Posted February 18, 2015 Simplest way is to still do defuns 1 for a single 1M or 1m for multiples 1 example shown (defun c:1 ( / obj ) (setq obj (entsel "\nPick object")) (command "CHPROP" obj "" "LA" "1" "") ) Quote
georgi9909 Posted February 20, 2015 Author Posted February 20, 2015 This is not working for me because I use 1,2,3,4,5,6,7,8 and 9 for switching between layers. Can it be modify to work when is selected object (step 1 select obcject; step 2 press 1,2,3,4,5,6,7,8 and 9 and press enter to change object layer) Quote
BIGAL Posted February 20, 2015 Posted February 20, 2015 There is a nice lisp that pick object it sets to layer and invokes the object as a command so pick a line and it asks for you to create a line. I will try to find it. We don't do repeat stuff or else would use all the time. I still think using a menu or toolbars would be easier. Quote
