kizaerf Posted February 23, 2015 Share Posted February 23, 2015 so, I have a raster image underlay in my drawing and I set the DRAWORDER to BACK in order to trace over. The problem is, when I do certain commands, like for instance, merge layers, or move something, it undoes the draw order and the image moves back to the front in a seemingly arbitrary way. The question would be, how do I set it so it stays in the back no matter what new layers I add or if I move something or delete something, etc. I just want it to stay put. any ides? Quote Link to comment Share on other sites More sharing options...
Dipali Posted February 23, 2015 Share Posted February 23, 2015 Try pitting it on its own layer and lock that layer. It'd may work Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 23, 2015 Share Posted February 23, 2015 Is the draw order actually changing? Do you REGEN when this becomes apparent? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted February 24, 2015 Share Posted February 24, 2015 You should check your DRAWORDERCTL system variable setting, and adjust it, as per the screen capture. I believe that the default value out of the box is , perhaps your setting has been changed. Dana's suggestion (REGEN) should reinstate the desired draworder display in your drawing. I didn't check it, but Dipali's suggestion also seems like a good viable alternative. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 24, 2015 Share Posted February 24, 2015 Interested to try this variable tommorrow have background image, then a wipeout then linework, must send to back in order and other trick is linework is at elev 1, else wipeout does just that. Quote Link to comment Share on other sites More sharing options...
Organic Posted February 24, 2015 Share Posted February 24, 2015 This is a problem I often have also. I will have to try your suggestions Dipali & Dadgad in the future. Quote Link to comment Share on other sites More sharing options...
