Selection Set for Elements Inside Polyline (including Polyline)
I found a LISP someone created that allows you to select a polyline and the program creates a selection set of all the elements inside the polyline. How can I get the program to include the polyline in the SS as well?
I tried to create an "en2" variable that is equal to the entity name of "pSS", then do (ssadd en2 ss) to add it onto the current selection set, but haven't gotten it to work. Any suggestions?
(vl-load-com)
;; Select window poly
(defun c:SelWP (/)
 (SelPoly "_WP")
;; Select objects inside a polyline
(defun SelPoly (WC / pSS ss ss1 n m en)
 (if (and
         (prompt "\nSelect polylines to form WPoly borders: ")
         (setq pSS (ssget '((0 . "LWPOLYLINE"))))
       (setq n (sslength pSS)) ;number of polylines selected
(setq ss (ssadd))
   (while (> (setq n (1- n)) -1)
     (if (and
           (setq ss1 (ssget WC (mapcar 'cdr (vl-remove-if-not '(lambda (item) (= (car item) 10)) (entget (ssname pSS n))))))
           (setq m (sslength ss1))	;number of objects inside of polyline
       (while (> (setq m (1- m)) -1)
         (setq en (ssname ss1 m)) ;en = list of entity names inside of polyline
  (ssadd en ss)
     (setq ss1 nil)
     (gc)
 (if (and ss (> (sslength ss) 0))
   (sssetfirst nil ss)
Replace the following into your posted routine .
(sssetfirst nil (ssadd ss (ssname pSS 0)))
Thanks for your help. I replaced (sssetfirst nil (ssadd ss (ssname pSS 0))) for (sssetfirst nil ss) but I am getting "error: bad argument type: lentitype ". Was I supposed to replace somewhere else?
Sorry I posted the reply without testing it :oops:
Replace / add the following .
(and
   (setq ss (ssadd)
             [color=red]ss (ssadd (ssname pSS 0) ss ))[/color]
Replace this ...
   (sssetfirst nil ss)
With this ...
(if (> (sslength ss) 1)
   (sssetfirst nil ss)
