drmdevalence Posted February 24, 2015 Share Posted February 24, 2015 Hi all. Im currently working on AutoCAD Architecture 2010. I am modeling a chair out of round tubing. On the chair thee are multiple small pins with a hole in and rounded top. afte i save and close the drawing, when i re open the drawing most of the rounde pins have turned into small square blocks. Even previous drawing have the same error. Any sugestions. Thank you Quote Link to comment Share on other sites More sharing options...
nestly Posted February 24, 2015 Share Posted February 24, 2015 Wecome to Cadtutor Are you using any special ACA objects, or only using core 3D tools and commands? Have you tried REGEN and or viewing with a different visual stye after the objects seem to change shape? A before and after screenshot would be helpful, as would a sample drawing with the object(s) you're having trouble with. Quote Link to comment Share on other sites More sharing options...
Patrick Hughes Posted February 25, 2015 Share Posted February 25, 2015 If it happens to be an appearance thing try setting Viewres to something like 5000 Quote Link to comment Share on other sites More sharing options...
drmdevalence Posted February 25, 2015 Author Share Posted February 25, 2015 Hello All. So the tubing is an extrusion i did along a polyline. The Smal pin had been revolved and then a hole subtracted from the revolved pin. The disaster image shows what happens. It first happend after i mailed the drawing to myself to work from home. Then i redrew the chair, and saved as another drawing. On opening the next day this is what i was left with. thanks Quote Link to comment Share on other sites More sharing options...
drmdevalence Posted February 25, 2015 Author Share Posted February 25, 2015 Sorry. Also it's not an apearance thing. the 3D object actually changed to this square 3D object. Freaks me out!!! Quote Link to comment Share on other sites More sharing options...
nestly Posted February 25, 2015 Share Posted February 25, 2015 If you attach a sample drawing, we can test with multiple versions of AutoCAD to see if it's an object handling issue, otherwise I have no idea. If it continues to happen, perhaps turn the "pin" into a Block. Quote Link to comment Share on other sites More sharing options...
drmdevalence Posted February 25, 2015 Author Share Posted February 25, 2015 2015 EGG DIAMOND MESH CHAIR_OPT 2H_2015 02 23.dwg. Hello, I have attached one of the previous drawings as the latest ones have failed again. Let me know if you figure something out. Thanks again for your Help. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 25, 2015 Share Posted February 25, 2015 No problems here with your drawing. Saved it out under another name after running the -PURGE and AUDIT commands on it then opened the drawing and still no problems. Quote Link to comment Share on other sites More sharing options...
steven-g Posted February 25, 2015 Share Posted February 25, 2015 It's fine in LT as well, how about posting a failed drawing, maybe that will show something. Quote Link to comment Share on other sites More sharing options...
nestly Posted February 25, 2015 Share Posted February 25, 2015 I also did not see the problem when opening with AutoCAD2011. You may try BREP command, which will remove the Solid History from the pins. Quote Link to comment Share on other sites More sharing options...
drmdevalence Posted February 25, 2015 Author Share Posted February 25, 2015 Hello again. please find failed drawing attached. You'll see most of the pins turned into a block. thank you 2015 EGG DIAMOND MESH CHAIR_FAILED.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted February 25, 2015 Share Posted February 25, 2015 How did you place those solids, it looks as though possibly you may have used the measure or divide command to place blocks and then exploded the blocks ? Is it possible that another block definition got mixed into the drawing. Quote Link to comment Share on other sites More sharing options...
nestly Posted February 25, 2015 Share Posted February 25, 2015 I think there's just something in the way the pins were created that's confusing AutoCAD (may or may not be version specific). If you display the Solid History (SHOWHIST=2) the box appears to be a bounding box around the cylinder that was pushed through the REVOLVE. Quote Link to comment Share on other sites More sharing options...
