kilari_venkatesh Posted February 27, 2015 Share Posted February 27, 2015 As you can see in the attachement at the bottom of dialog box a rectangular pink box not occupying the full white colour image.Please suggest... : row { : image { key = "im" ; height = 2.15 ; //0.9495 width = 10 ; //1.00 fixed_width = true; //fix the width fixed_height = true; //fix the height } : paragraph { : text_part { label = "Designed and Created"; } : text_part { label = "XYZ"; } } } ______________________________Lisp_____________________________ (setq w (dimx_tile "im") h (dimy_tile "im") ) ;_ end of setq (start_image "im") ;(fill_image 0 0 w h 1) (slide_image 0 0 w h "hatch") (end_image) Quote Link to comment Share on other sites More sharing options...
hmsilva Posted February 28, 2015 Share Posted February 28, 2015 Hi kilari_venkatesh, I don't deal with DCL for a long time, but, let's see if I can assist... A simple soluction would be, to set the background color to -15, the dialog color, it does not modify the image size, but you'll not see the white... e.g. : row { : image { key = "im" ; height = 2.15 ; //0.9495 width = 10 ; //1.00 color = -15 ; //the dialog color fixed_width = true; //fix the width fixed_height = true; //fix the height } : paragraph { : text_part { label = "Designed and Created"; } : text_part { label = "XYZ"; } } } To fit the image to the tile, you'll have to change the image size, and change the image offset. e.g. (setq w (dimx_tile "im") h (dimy_tile "im") ) ;_ end of setq (start_image "im") (fill_image 0 0 w h 1);;comment after you set the correct img size and offset (slide_image -25 -5 (* w 2) (* h 2) "hatch") (end_image) Hope that helps Henrique Quote Link to comment Share on other sites More sharing options...
