I am having a bit of trouble here with this. Is there a lisp guru out there who can help me. I hope I have explained my problem clearly enough :)
Insertit.lsp.pdf
I'm farily new to writing lisp, but I'll give you my opinion.
You can add multiple commands to a lisp, giving you the options you want. I would add a seperate command for each FFL you were referring to.
Insertit.lsp
;;  152ffl            ;;
(defun c:152ffl ()
(on_hold)
(defun on_hold ()
(sp_inset)
(if(/= tm_ssget nil)
(command "_.erase" tm_ssget "")
(command "_.ucs" "")
(setvar "cecolor" "8")
(if(tblsearch "BLOCK" "DwgBOMBlockTableRecord3")(command "_.insert" "152FFL"
(list (* -10 real_scale) (* 12.5 real_scale)) real_scale real_scale 0))
(sp_outset)
;;  185ffl            ;;
(defun c:185ffl ()
(on_hold)
(defun on_hold ()
(sp_inset)
(if(tblsearch "BLOCK" "DwgBOMBlockTableRecord3")(command "_.insert" "185FFL"
(sp_outset)
;;  200ffl            ;;
(defun c:200ffl ()
(on_hold)
(defun on_hold ()
(sp_inset)
(if(tblsearch "BLOCK" "DwgBOMBlockTableRecord3")(command "_.insert" "200FFL"
(sp_outset)
Edited by jonathann3891
