How to select an object created by entmakex ?
vanowm
Hello.
I have a function that draw line:
(defun drawLine (start end)
   (entmakex (list
                 '(0 . "LINE")
                 '(100 . "AcDbEntity")
                 '(100 . "AcDbLine")
                 '(8 . "")
                 (cons 9 start)
                 (cons 10 end)
How do I make it select that line so it would show with grips?
Thank you.
odd why you use 9 as startpoint
   (entmakex (list
                 '(0 . "LINE")
                 '(100 . "AcDbLine")
                 [b];'(8 . "")[/b]
                 (cons [b]10 [/b]start)
                 (cons 11 end)
(defun c:demo ()
 (setq ss (ssadd))
(setq p1 (getpoint))
(setq p2 (getpoint p1))
 	(setq newline (drawLine p1 p2))
(sssetfirst nil (ssadd newline ss ))
Note that if ssadd is called without the selection set argument, the supplied entity will be automatically added to a new selection set, e.g.:
(defun c:test ( / p q )
   (if (and (setq p (getpoint "\nStart: "))
            (setq q (getpoint "\nEnd: " p))
       (sssetfirst nil (ssadd (drawline (trans p 1 0) (trans q 1 0))))
Also, note that the subclass markers (DXF group 100) are not required for LINE entities:
(defun drawLine ( start end )
   (entmakex
       (list
          '(0 . "LINE")
           (cons 10 start)
           (cons 11 end)
Thank you very much.
These little details are very useful for newbies! Thanks again for taking your time to teach us ;)
