MonkeyTurnip Posted March 18, 2015 Share Posted March 18, 2015 sounds simple, and is but, and there always is one I don't have the ability to upload a dwg, I will do as soon as I can, so i'll try and explain as best I can if I have a dynamic block like -[] so a line coming out of a box/square. how can I rotate/move the line around the square keeping it perpendicular to the square, but always touching the square, and never going away or encroaching into it. I can not use a wipeout as the square is to encompass a detail, and attached to the line is a detail number. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 19, 2015 Share Posted March 19, 2015 Why not use a box/square with eight lines controlled by a visibility parameter? Have a line at each corner and one at each midpoint. Shouldn't that cover about 99% of all uses? Quote Link to comment Share on other sites More sharing options...
steven-g Posted March 19, 2015 Share Posted March 19, 2015 It's not something you'll get (easily) with a single grip, but with a rotate and a linear move, how about this as a starting point RoundSquare.dwg Quote Link to comment Share on other sites More sharing options...
MonkeyTurnip Posted March 24, 2015 Author Share Posted March 24, 2015 It's not something you'll get (easily) with a single grip, but with a rotate and a linear move, how about this as a starting point Sorry for the late response, but that is actually perfect (sort of) I didn't think to limit the rotation angle by 90degrees at all. and that answered ally my problems (well with this block) I took the box out of the selection set and rotated just the line. so simple. Quote Link to comment Share on other sites More sharing options...
