pmxcad Posted March 28, 2015 Posted March 28, 2015 Hello all, i`ve made a script that makes a layer "XREF" and make it current. And set the layout to modelspace. Aftert that i want to attach a XREF. This xref drawingfile is in a subfolder of the main drawing. Because the file name of the xref is always different so i used a * (asterik) as filename. So this is not working. There is always just one Xref file in the subfolder. See script: -LAYERMAKEXREFLAYOUTSETMODEL-XREFATTACH.\XREF\*.DWG0,0,0110 Is there a way to get this working, script or lisp? Problem is the * as filename. Thanks, PmxCAD Quote
VVA Posted March 29, 2015 Posted March 29, 2015 (edited) Try it (defun C:XATT (/ path lst sett) ;;;Attach Xref from a subfolder named XREF of the main drawing ;;;Posted http://www.cadtutor.net/forum/showthread.php?91669-looking-for-a-lisp-or-script-to-attach-a-xref ;;;http://forum.dwg.ru/showthread.php?p=1387542 (vl-load-com) (setvar "TILEMODE" 1) ;_switch to Model (setq sett (mapcar '(lambda (x)(getvar x)) '("INSUNITSDEFSOURCE" "INSUNITSDEFTARGET" "INSUNITS" "EXPERT"))) (vl-cmdf "_Layer" "_Make" "Xref" "") ;_make Layer named Xref (setq path (vl-string-right-trim "\\" (getvar "DWGPREFIX")) ;_get path of the main drawing path (strcat path "\\" "Xref") ;_get path to subfolder named Xref ) (mapcar '(lambda (x) (vl-catch-all-apply '(lambda () (vla-attachexternalreference (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)) ) x (vl-string-translate ",.$#=@^\`" "-_dpeaut" (vl-filename-base x) ) (vlax-3d-point '(0 0 0)) 1 1 1 0 :vlax-true ) ) ) ) (setq lst (z-files-in-directory path "*.dwg" nil)) ) (mapcar '(lambda (x y)(setvar x y)) '("INSUNITSDEFSOURCE" "INSUNITSDEFTARGET" "INSUNITS" "EXPERT") sett ) (if lst (alert (strcat (itoa (length lst)) " xref attached from\n" path) ) (alert (strcat "Nothing xref found in\n" path)) ) (princ) ) ;;;* Function z-files-in-directory returns a list of files located in a given ;;;* directory ;;;* Author: Vitaly Zuenko (ZZZ) ;;;* Parameters: ;;;* Directory - path eg "D:\\my documents\\ZEF\\Lisp" ;;;* Pattern - template such as "*. lsp", or a list'("*. dwg "" *. dxf ") ;;;* Nested - search in subfolders: t (yes) or nil (no) ;;;* Example call: ;;;(Z-files-in-directory "D:\\my documents\\ZEF\\Lisp" "*. dwg" t) ;;;(Z-files-in-directory "D:\\my documents\\ZEF\\Lisp"'("*. dwg "" *. dwt ") t) ;;;============================================================================= (defun z-files-in-directory (directory pattern nested /) (if (not (listp pattern)) (setq pattern (list pattern)) ) (if nested (apply 'append (append (mapcar '(lambda (_pattern) (mapcar '(lambda (f) (strcat directory "\\" f)) (vl-directory-files directory _pattern 1) ) ) pattern ) ;_ mapcar (mapcar '(lambda (d) (z-files-in-directory (strcat directory "\\" d) pattern nested ) ) (vl-remove "." (vl-remove ".." (vl-directory-files directory nil -1)) ) ) ) ) (apply 'append (mapcar '(lambda (_pattern) (mapcar '(lambda (f) (strcat directory "\\" f)) (vl-directory-files directory _pattern 1) ) ) pattern ) ) ) ) (princ "\nType XATT in command line") (vl-load-com) Edited March 31, 2015 by VVA Quote
pmxcad Posted March 29, 2015 Author Posted March 29, 2015 Wow, super. It works perfect VVA. Thanks, PmxCAD Quote
