How can I calculate area by lisp?
Rain0923
  • Replies 28
  • Rain0923
    14
  • pBe
    9
  • neophoible
    5
  • Alex-77
    1
Posted Images
2. total red pline area / black pline area
Total RED area value divided by BLACK area value? ---> 0.238058 ?? or the other way around? 4.20066 ??
(defun c:demo ( / _total ss ssd TareaRed TareaBlack ComputedArea)
(defun _total (sel / Value)
     (repeat (setq i (sslength sel))
                      (setq Value (cons (vlax-curve-getarea (ssname sel (setq i (1- i)))) Value)))
     (apply '+ Value)
(defun _Rtos (v)(rtos v 2 2))
      (if (and  (princ "\nSelect RED pline(s)")
                (setq ss (ssget '((0 . "LWPOLYLINE"))))
                (princ "\nSelect Black pline")
                (setq ssD (ssget '((0 . "LWPOLYLINE"))))
                (setq TareaRed (_total ss))
                (setq TareaBlack (_total ssd))
                (setq ComputedArea ( / TareaRed TareaBlack))
                (alert (strcat "\nTotal area for RED pline(s): " (_rtos TareaRed )
                "\nTotal area for BLACK pline(s): " (_rtos TareaBlack )
                "\nTotal RED divided by BLACK: " (_rtos ComputedArea)
                "\nPercentage: "  (_rtos (* 100.00  ComputedArea)) "%"))
Edited by pBe
Thanks
0.238058 is right.
This lisp is good but the layer is not in CSM then it can't use.
Can it change not lock any layer name or color?
(defun c:demo ( / RED ss s TArea RED_TOTAL BLACK)
                (setq  RED nil ss (ssget '((0 . "LWPOLYLINE")(8 . "CSM"))))
                (setq s (ssget "_:S" '((0 . "LWPOLYLINE"))))
                      (setq RED (cons (vlax-curve-getarea (ssname ss (setq i (1- i)))) RED)))
        (setq TArea (/ (setq RED_TOTAL (apply '+ RED))
                               (setq BLACK (vlax-curve-getarea (ssname s 0)))))
                (princ (strcat "\nTotal area for RED pline(s): " (rtos RED_TOTAL 2 2)))
                (princ (strcat "\nBlack Pline area: " (rtos BLACK 2 2)))
                (princ (strcat "\nTotal RED divided by BLACK: " (rtos TArea 2 2)))
But of course, just remove (8 . "CSM") from the code. What other conditions to you need to add? Is the divisor always one entity?
Great!!It can use now.
Is any probably show percentage?
No, the divisor is not always one entity.Can it update?
How do you get the percentage Rain0923? Show me so there would be no confusion
Yes
It like show 0.238058 and 23.81%...
Thanks
Yes
Can it do like in the attachment?
YES, but are you aware you can do the ADD/Subtract using the native area command?
We can go back and forth on this, so take a deep breath write down ALL the conditions, sample drawings, results and all. Then post it here.
You should have done all that from the get-go Rain0923. :)
Yes,sorry bother you again.My English is not good so sometimes I don't know how to explain my question.Sorry again.....
This is another demand. I want separate to two lisp.
1.You give to me already.
2.So.......ask you this question just now.
and I clearly condition more in the attachment.Please
(still need all area answers and percentage)
teat2.dwg
This is another demand...
I will look into this, cant seem to wrap my head on how to go about the selection. its definitively doable.
EDIT: show us an example where there are two or more green area for divisor.
Edited by pBe
Please have the file, I add divisor in the file.Thanks:oops:
teat3.dwg
Still thinking of the best way to select the objects. IMO test3.dwg does not represent the whole picture. We need a real world drawing sample Rain0923
One question:
Layers.... It would be loads easier for selection if the objects are set to a specific layer but then again maybe not.
We can do pairs then toggle between two boundaries to identify which one is to be subtracted. or even prompt selection with Subtract / ADD /Divide mode, much like the native Area command only more user friendly [ maybe :unsure: havent really used Area command myself ]
pBe, actually, you could use the AREA command in the routine and retrieve the result using (getvar "AREA"), but I doubt that's your preference.
razara, it would be best if you show the output you are expecting for the sample drawing you have provided. Type it in just the way you want it to show.
Are you always selecting in pairs, except for the boundary divisors? Can you have more than two divisors?
Why not just explain what you are actually trying to accomplish with these calculations?
-->The objects are not set to a specific layer.
-->You are right that is really more friendly.
Maybe we can let question more sample that like calculating machine
with Subtract / ADD /Divide mode they can use selection by user.8)
lisp can do?
Thanks
One question:
That is correct neophoible, but might as well use the AREA command itself outside the routine for ADD/SUBTRACT and then run a short code for divide using (getvar 'area) [as you suggested] as an argument.
lisp can do?
Thanks
Your maybe onto something there Rain0923.
