Hey,guys.
(action_tile "th" "(setq scl (distof $value))")
What does this mean ?
"th" is a key of "Edit_box",
I want "Edit_box" can only enter Numbers, can't enter character. How to do ?
I want "Edit_box" can memory , when dialog exit--->start again, the value in the edit box is the last , not default value . How to do ?
Thanks for any help.
Distof "Converts string which contains a real, display format by mode".
(setq scl $value) will now accept alpha or 0-9 but it will be a string not a number in case of 0-9.
You can pass a default value to be used in your DCL.
No code posted so no idea how to show example.
Tks, but I need a sample.:( :cry:
if
is your dialog file
editbox is dcl ID
"number" is the key for edit_box, or "th" of yours.
*memory* is global default value
(setq *memory* (if (and *memory* (= (type *memory*) 'STR))  *memory* "[b]0.000[/b]"))
(defun c:test (/ dcl_id dd)
 (setq dcl_id (load_dialog [b][color="red"]<editbox.dcl>[/color][/b] ) dd 1)
 (while
   (or (not (numberp (read *memory*)))(= dd 1))
   (new_dialog "[color="red"]editbox[/color]" dcl_id)
   (set_tile "[color="red"]number"[/color] *memory*)
   (action_tile "accept" "(setq *memory* (get_tile \"number\"))(done_dialog 0)")
   (setq dd (start_dialog))
   ) ;_ end of while
 (unload_dialog dcl_id)
 ) ;_ end of defun
if
is your dialog file
editbox is dcl ID
 (while
   ) ;_ end of while
 ) ;_ end of defun
Thank you very much , hanhphuc , I will study carefully!
