Insert block in midpoint of lines filtered by length
Goodmorning, I would need a lisp that automatically insert a block in the midpoint of every specific line of predetermined lenght.
I've created in my drawing several block called:
-"50m" -> insert in midpoint of lines with 500 mm
-"100m" -> insert in midpoint of lines with 1000 mm.
ecc..
I write this coarse code :?
(defun C:blockparlines (/)
 (setq s (ssget "x" '((0 . "LINE" ))))
;FILTER SELECTION FOR LINES WITH LENGTH 500 mm
(setq ss1 (ssadd))
(setq lung 500)
(setq ss2 s)
(if ss2 (progn
(setq i 0  ssl (sslength ss2))
(repeat ssl
 (setq ename (ssname ss2 i))
 (setq ll (distance (cdr (assoc 10 (entget ename))) (cdr (assoc 11 (entget ename)))))
 (if (= lung ll)(ssadd ename ss1))
 (setq i (1+ i))
(princ (strcat (itoa (sslength ss1)) " generated block's of 500 mm."))
;(sssetfirst nil ss1)
;INSERT BLOCK IN MIDPOINT of 500 mm
(setq name "50M")
(repeat (setq i (sslength ss1))
      (setq e (entget (ssname ss1 (setq i (1- i)))))
      (entmakex
        (list '(0 . "INSERT")
              (cons 10
                    (mapcar (function (lambda (q p) (/ (+ q p) 2.)))
                            (setq p1 (cdr (assoc 10 e)))
                            (setq p2 (cdr (assoc 11 e)))
              (cons 2 name)
              (cons 50 (angle p1 p2))
              '(41 . 1.0)
              '(42 . 1.0)
              '(43 . 1.0)
;RESET SS1
 (setq ss1 nil)
 (setq ss1 (ssadd))
;FILTER SELECTION FOR LINES WITH LENGTH 1000 mm
(setq lung 1000)
(setq ss2 s)
(if ss2 (progn
(repeat ssl
 (setq i (1+ i))
(princ (strcat (itoa (sslength ss1)) " generated block's of 1000 mm."))
;INSERT BLOCK IN MIDPOINT of 1000 mm
(setq name "100M")
      (entmakex
              (cons 10
              (cons 2 name)
              '(41 . 1.0)
              '(42 . 1.0)
              '(43 . 1.0)
;RESET SS1
 (setq ss1 nil)
 (setq ss1 (ssadd))
Here is the bugs:
-it doesn't consider the lines along XZ YZ plane? I don't understand why.
-this is very long code i've got 10 or more blocks to insert by length. An easy way to get the routine optimized?
Thanks
Miller
Can you list the rest of your block names with their related lengths ?
List of the blocks to associated at the lines:
"50M" -> in midpoints of lines of length 500 mm
"100M" -> in midpoints of lines of length 1000 mm
"150M" -> in midpoints of lines of length 1500 mm
"200M" -> in midpoints of lines of length 2000 mm
"250M" -> in midpoints of lines of length 2500 mm
"300M" -> in midpoints of lines of length 3000 mm
Try this and let know .
[ NOT TESTED ]
(defun c:Test  (/ l ss)
 ;;;	Tharwat 27.4.2015	;;;
 (setq l '(("50M" 500)
           ("100M" 1000)
           ("150M" 1500)
           ("200M" 2000)
           ("250M" 2500)
           ("300M" 3000))
 (if (setq ss (ssget '((0 . "LINE"))))
   ((lambda (i / sn a b f)
      (while (setq sn (ssname ss (setq i (1+ i))))
        (if
          (and (vl-some
                 '(lambda (x)
                    (equal
                      (distance
                        (setq a (cdr (assoc 10 (entget sn))))
                        (setq b (cdr (assoc 11 (entget sn)))))
                      (cadr (setq f x))
                      1e-)
                 l)
               (tblsearch "BLOCK" (car f))
           (entmake (list '(0 . "INSERT")(cons 10 (mapcar (function (lambda (q p) (/ (+ q p) 2.)))
                                                          a
                                                          b
                          (cons 2 (car f))
                          (cons 50 (angle a b))
                          '(41 . 1.0)
                          '(42 . 1.0)
                          '(43 . 1.0)
                    ))))  -1)
Thanks It works! :D
But I need to modify a little bit.
Filter selection for vertical lines Z and reject all the other lines from selection.
Thanks again
Thanks It works! :D
Thanks again
Excellent , you are welcome :)
I am sorry , I did not get your point . explain it a little bit further .
mlu73fc.png?1
I would like to select ONLY the vertical lines (as you can see in picture in RED) that belong plane YZ XZ before filtering by distance.
Is that possible?
Thanks
We can iterate through the selection for a specific criteria of the lines , and if it is matched let the codes move to the other criteria to check it out .
Can you upload that sample drawing ?
Here it is.
You have vertical lines in red ready with length 1000 and 1500.
sample.dwg
I think that you can't because also the white lines are have a Z coordinate equal to either start/end point of red lines .
You may work around this issue by filtering the lines by Layer / Color ... etc.
I found this your old code ;) and with a little modify It may works.
There are still some bug and it's not optimized.
(defun c:VHlines ( / _Ang *error* kw e i sn ss )
 ;;; Tharwat 13. Dec. 2012  ;;;
 ;;; modified by miller87 27/04/2015
 (defun _Ang (e) (angle (cddr (assoc 10 e)) (cddr (assoc 11 e))))
 (defun *error* (msg) (princ "\n Error...*Cancelled*"))
 (if (and (progn
                 (setq kw "Vertical"
          (setq s  (ssadd)
                ss (ssget "_x" (list '(0 . "LINE") (cons 410 (getvar 'ctab))))
       (setq sn (ssname ss (setq i (1- i)))
             e  (entget sn)
       (cond ((eq kw "Vertical")
              (if (or (equal (_Ang e) (* pi 0.5)) (equal (_Ang e) (* pi 1.5)))
                (ssadd sn s)
             ((eq kw "Horizontal")
              (if (or (equal (_Ang e) pi) (equal (_Ang e) 0.))
                (ssadd sn s)
             (t
              (if (or (equal (_Ang e) (* pi 0.5)) (equal (_Ang e) (* pi 1.5)) (equal (_Ang e) pi) (equal (_Ang e) 0.))
                (ssadd sn s)
     (sssetfirst nil s)
Maybe :
[b][color=BLACK]([/color][/b]defun c:mvert [b][color=FUCHSIA]([/color][/b]/ ss i en ed p1 p2 z1 z2 ll ip bn[b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"LINE"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
     [b][color=NAVY]([/color][/b]setq i 0[b][color=NAVY])[/color][/b]
     [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
            [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b]
                  p1 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 10 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
                  p2 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 11 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
            [b][color=MAROON]([/color][/b]and [b][color=GREEN]([/color][/b]equal [b][color=BLUE]([/color][/b]car  p1[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]car  p2[b][color=BLUE])[/color][/b] 1e-8[b][color=GREEN])[/color][/b]
                 [b][color=GREEN]([/color][/b]equal [b][color=BLUE]([/color][/b]cadr p1[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cadr p2[b][color=BLUE])[/color][/b] 1e-8[b][color=GREEN])[/color][/b]
                 [b][color=GREEN]([/color][/b]setq z1 [b][color=BLUE]([/color][/b]caddr p1[b][color=BLUE])[/color][/b]
                       z2 [b][color=BLUE]([/color][/b]caddr p2[b][color=BLUE])[/color][/b]
                       ll [b][color=BLUE]([/color][/b]abs [b][color=RED]([/color][/b]- z1 z2[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
                       ip [b][color=BLUE]([/color][/b]list [b][color=RED]([/color][/b]car p1[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cadr p2[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]+ [b][color=PURPLE]([/color][/b]min z1 z2[b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]* ll 0.5[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
                       bn [b][color=BLUE]([/color][/b]strcat [color=#2f4f4f]"M"[/color] [b][color=RED]([/color][/b]rtos ll 2 0[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
                 [b][color=GREEN]([/color][/b]tblsearch [color=#2f4f4f]"BLOCK"[/color] bn[b][color=GREEN])[/color][/b]
                 [b][color=GREEN]([/color][/b]entmake [b][color=BLUE]([/color][/b]list [b][color=RED]([/color][/b]cons 0 [color=#2f4f4f]"INSERT"[/color][b][color=RED])[/color][/b][b][color=RED]([/color][/b]cons 2 bn[b][color=RED])[/color][/b][b][color=RED]([/color][/b]cons 10 ip[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
            [b][color=MAROON]([/color][/b]setq i [b][color=GREEN]([/color][/b]1+ i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
The INSERT angle is moot because all LINE point values are WCS.
-David
Works!
I modified with the correct names of my blocks:
50M, 100M, 150M, 200M, 250M, 300M
Here the final results:
(defun c:mvert (/ )
(and (setq ss (ssget "X" '((0 . "LINE"))))
     (setq i 0)
     (while (setq en (ssname ss i))
            (setq ed (entget en)
                  p1 (cdr (assoc 10 ed))
                  p2 (cdr (assoc 11 ed)))
            (and (equal (car  p1) (car  p2) 1e-
                 (equal (cadr p1) (cadr p2) 1e-
                 (setq z1 (caddr p1)
                       z2 (caddr p2)
                       ll (/ (abs (- z1 z2)) 10.0)
		lll (* ll 10.0)
                       ip (list (car p1) (cadr p2) (+ (min z1 z2) (* lll 0.5)))
                       bn (strcat  (rtos ll 2 0) "M"))
                 (tblsearch "BLOCK" bn)
                 (entmake (list (cons 0 "INSERT")(cons 2 bn)(cons 10 ip))))
            (setq i (1+ i))))
 (prin1)
I could change the name of the blocks but manipulating lisp is more pleasant!!
Thanks David
:shock: LOL
I did assume that the BLOCK table definitions exist.
You could always add BLOCK creations or an INSERT call
-Davis
