Proctor Posted April 30, 2015 Share Posted April 30, 2015 Hello: I'm trying to create a line type that basically needs to look just like the pic below (a ladder type pattern). I was unable to do as just a linetype so thought I would try with the use of a shape file. therefore; I first create my shape file via -> Express Tools-> Make Shape. after; I create my linetype via -> Express Tools -> Make Linetype. When doing this part, I specify the shape file. I think perhaps my problem may be in selecting the start end ending points for the linetype??? (see my other pic with the green circles...these represent approx. for where I clicked for my starting and ending points. When, I use my new linetype and it comes out like a straight line????? I'm confused. I thought the start point and end points should represent the pattern. Any advice is truly appreciated. Thanks, Proctor Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 1, 2015 Share Posted May 1, 2015 Linetypes have a habit of not quite working the way you want sometimes just trimming a fraction can make a difference, I think sometimes its easier to use a lisp to create a pattern, you know it will work everytime. Use GROUP to join them back into just that a group of objects you can trim etc. You can create dynamic patterns as you stretch they add items. This is an example supplied for CIV3d pretty fantastic. Parking Tools - Metric.dwg Quote Link to comment Share on other sites More sharing options...
Proctor Posted May 6, 2015 Author Share Posted May 6, 2015 Hi Bigal: thank you very much for your response and also for sending the drawing file for me to see. Unfortunately, I was unable to open it using my version of Cad (2014). Also, I've heard of lisp but not sure what that is...... I was able to get my linetype to work - somewhat. It now displays the shape very nicely. The issue I'm having is that when I go to use the linetype, the start and end points are at a distant from my shape (see pic). I need the start and end points to coincide with where the shape begins and ends. I used Express tools when creating my linetype and it did ask me for the start and end points.....for these, I selected the starting of my shape and then where the shape ended. Do you know if this is possible to do? Here's the code I have thus far: *SIGNBOX,signbox A,6.187498,[sIGNBOX,signbox.shx,y=-.000035,s=1,r=90],6.187502 Thank you again for your help, Proctor Quote Link to comment Share on other sites More sharing options...
eldon Posted May 6, 2015 Share Posted May 6, 2015 I thought that you were using a lisp for the spacing. Did you ever manage to extract the lisp as in your previous post in May 2010? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 7, 2015 Share Posted May 7, 2015 Wow eldon 2010 post check up ! Proctor you may need civ3d for some reason the dwg is 2013. Its hard to test as I only have CIV3d but its knows it has MAP, CIV3d & Acad when needed. Quote Link to comment Share on other sites More sharing options...
