Mansur Posted May 12, 2015 Share Posted May 12, 2015 Dear all, I tried to copy an object from another drawing to my working drawing through copyclip command, and when I paste it in my present drawing, all the lines on the drawing changes to higher thickness (like drawn with Pline with bigger width). Even i tried to attach the drawing after making the object as a block and paste, still the copied objects looks same. Kindly help me to solve this issue. Thanks.. Quote Link to comment Share on other sites More sharing options...
ttray33y Posted May 12, 2015 Share Posted May 12, 2015 check Layers default values. Quote Link to comment Share on other sites More sharing options...
Mansur Posted May 12, 2015 Author Share Posted May 12, 2015 Thank you ttray33y I manage to get the lines right by changing the Line Weight to Zero.. Quote Link to comment Share on other sites More sharing options...
ttray33y Posted May 12, 2015 Share Posted May 12, 2015 Thank you ttray33yI manage to get the lines right by changing the Line Weight to Zero.. your welcome mate. Quote Link to comment Share on other sites More sharing options...
