vernonlee Posted May 13, 2015 Share Posted May 13, 2015 This is the setup DRAWING 1 (saved in c:\template) contains Block A, Block B, Block C & Block D DRAWING 2 (saved in d:\) contains Block A, Block B & Block C (I HAVE ADDED c:\template to the "support file search path") How to draft the macro script such that only Block A & Block C from DRAWING 2 can be redefined base on Block A & Block C from DRAWING 1? Thanks Quote Link to comment Share on other sites More sharing options...
pmxcad Posted May 13, 2015 Share Posted May 13, 2015 i use the following script: (load "f:/cad/Lisp-Scrips/blkredef.lsp") ; (BlkRedef "f:\\cad\\Blocks\\---.dwg") ATTSYNC N --- --- = blockname (attsync part only for blocks with attributtes) first load the lisp (blkredef.lsp) PmxCAD blkredef.lsp Quote Link to comment Share on other sites More sharing options...
