Auto hatch after closing a polyline
Hi,
Is is possible to hatch a box automatically when using PL. I want to be able to trace around an object and soon as I close the PL it will hatch.
all help appreciated,
Keith
Easy done via lisp
; create pline by picking points press enter when finished
(command "_pline")
(while (= (getvar "cmdactive") 1 ) (command pause)
(command "-hatch" "S" "L" "" "") ;do stuff here like pattern rotation scale
Thanks BIGAL
Just a little lost how to enter the code...
So a more turn key solution would look something like this, using ANSI31 pattern, at scale 10.5, rotation 0.
(defun c:polyhat ()
 (command "_pline")
   (command pause)
 (command "-hatch" "S" "L" "" "_P" "ANSI31" "10.5" "0.0" "")
  1. Save that code into a file using NOTEPAD.
  2. Name the file POLYHAT.LSP (make sure to enclose the file name in quotes when saving so that it won't append the "TXT" file extension)
  3. Drag+drop the file into the AutoCAD editor.
  4. (It may complain about the location of the file not being secure - see this for more info)
  5. Type in the command POLYHAT.
  6. Start creating...
  • 9 months later...
Hi rkmcswain,
I'm looking for this function. But, i want integrate it in a macro in my tool palette, without call LISP or other macro.
pline command, worked. hatch command on the last object, worked. But, the second function after the first, in same time, with cmdactive variable doesn't work ...
Have u an issue ? (In LISP case, the function is perfect)
If you just want a hatch button in the tool palette, then forget about lisp, macros, and everything else.
Just create a hatch object in a drawing, set the properties like you want, then drag and drop this hatch object into the tool palette.
From that point on, you can create that hatch using the new tool palette button - no programming needed.
I want to do the same thing that BIGAL. Draw a pline and "autohatch" it.
Except that I want to find the synthax to integrate it in my macro field. That's possible ?
A couple of ways copy the code to the file acaddoc.lsp it will then auto load it for you then just type polyhat, or you can edit the tool palette to ^c^cpolyhat or ^c^c(load "polyhat")(command "polyhat")
