I have the statement.
Document acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
in a form routine.
I would like to be able to use acDoc in all my form routines. How do I make acDoc usable within my form?
Thank you,
A simple way is to add a parameter in the constructor and pass it in.
public AcadForm(Document acDoc )
Could you give me a better more complete example?
I am somewhat new to this. I don't even know what a constructor is?
Thank you,
More complete examples often follow the posting of the code you're having trouble with. :thumbsup:
Your plug-in exists within a Namespace, which implements Classes (aka Types), which provide Properties, Methods, and Events. A Constructor 'builds' or instantiates an instance of the Class (Type), and can be Overloaded (provide more than one Method, each accepting a different set of parameter, if any at all).
Since you didn't post code, I can only speculate that you call your Form within a particular Method, simply add a Form Constructor, which accepts 'Document acDoc' as parameter within your Form's Class, and then pass it along:
Pseudo-code:
// <snip>
Document acDoc = acDocs.MdiActiveDocument;
MyForm myForm = new MyForm(acDoc);
//<-- do something useful
// <snip>
