northernmach Posted June 5, 2015 Share Posted June 5, 2015 I have been using Inventor since about 2006 and currently on version 2010. Most of what I do is very simple very rarly having a need to get into 3D sketching and surfaces. I currently am having an issue with simply trying to remove a scallop area off an axe blade that I am modifying. Attached is the file which has a boundry patch that I am just trying to extrude up through the original face cutting away the material thus leaving a scallop. Can someone explain a process for doing this. I have tried to use thicken/offset and get an error message when trying and am not familiar enough with tools to try a different way. Thanks, Chad northern_straight.ipt Quote Link to comment Share on other sites More sharing options...
