m_sherif005 Posted June 6, 2015 Share Posted June 6, 2015 Hi there I am trying to calculate length of polylines that a part of them are in a distance of another. Is there a way to routine this process Quote Link to comment Share on other sites More sharing options...
m_sherif005 Posted June 6, 2015 Author Share Posted June 6, 2015 for example I have a polyline with 52m length and this is neiber with another with 13m length witches its 5m is in 0.3m distance from 1st polyline. I want extract this polyline neiber length by routine. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 7, 2015 Share Posted June 7, 2015 No idea what you want post a image or dwg. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 7, 2015 Share Posted June 7, 2015 for exampleI have a polyline with 52m length and this is neiber with another with 13m length witches its 5m is in 0.3m distance from 1st polyline. I want extract this polyline neiber length by routine. I think the attached screenshot pretty much describes what you are after, at the most simple, with the two lines parallel, would you agree? Is the length which you hope to extract, only the 5 meter portion of the total length? Quote Link to comment Share on other sites More sharing options...
m_sherif005 Posted June 7, 2015 Author Share Posted June 7, 2015 I think the attached screenshot pretty much describes what you are after, at the most simple, with the two lines parallel, would you agree?Is the length which you hope to extract, only the 5 meter portion of the total length? Yes of course. This illustrates exactly my mean. In addition lines may be not parallel and may a part of line not end or start be in 0.3m distance. Regards Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 8, 2015 Share Posted June 8, 2015 What steps do you use now, to do this? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 9, 2015 Share Posted June 9, 2015 A method suggestion pick near end pline 1, pick near end pline 2 then code know 2 ends and can do some perp calcs etc No code only idea. Quote Link to comment Share on other sites More sharing options...
