SIDRIX Posted June 11, 2015 Share Posted June 11, 2015 Hello, I would like finally understand how to properly use the layer state manager. In the first moment it seems simple, I save a stile via save button in my model space, then for example I make some modifications (freeze, thaw) with the layer states in some other layout viewports. But then I want to restore everything as I saved it with the save button, but it seems that they don't restore back. It looks that my modifications are automatically saved on my saved layer state. I just want to save layer states and after messing around layout viewports get back that state that I had. Look that I'm missing some fundamental understanding how this thing works. Can someone give me instruction how to do it right? And one more question, when I push the save button the layer st. dialog box automatically closes, Its annoying if I experiment and do that a lot. How to keep the box on? Thank you I will be great full for your help. Quote Link to comment Share on other sites More sharing options...
SIDRIX Posted June 11, 2015 Author Share Posted June 11, 2015 sorry, mistake in text ... I restore with the restore button .... Quote Link to comment Share on other sites More sharing options...
SIDRIX Posted June 12, 2015 Author Share Posted June 12, 2015 After thinking a lot and experimenting, trying to read some, I finally understood. When I restore a layer state it applies to model and all layouts, but not to layout viewports!!! To change only a viewport state I must enter that viewport and select a layer state that is a layout kind of state (not model) saved in a viewport. So if I have many layouts and different viewports I must have a saved layer state for each of them. Simple but it so took much energy to understand this. Would be nice if there was a chance to change saved states for model, layouts and layout viewports with one click. Is there a way? Quote Link to comment Share on other sites More sharing options...
steven-g Posted June 12, 2015 Share Posted June 12, 2015 I never use layer states, so not to sure how it would work, but I would imagine it is possible using macro's, it is certainly an option in the command line version of the layer manager to change to a named layer state, so at least in theory you should be able to have a toolpalette or toolbar button set up for each layer state. Quote Link to comment Share on other sites More sharing options...
