acjam Posted June 12, 2015 Share Posted June 12, 2015 Hi all, I've been sent a drawing sheet by an architect to use with a drawing of mine. When I load up the dwg, the viewport set up in paperspace has an imperial scale (1/127"=1'0" etc). However, both the architect and myself are in the UK so we need to work in decimal. I've checked the drawing units and they *seem* to be set to decimal, so I'm a bit confused! If I insert a new viewport it still comes up as imperial. How can I switch their viewport back to decimal? Quote Link to comment Share on other sites More sharing options...
Tiger Posted June 12, 2015 Share Posted June 12, 2015 If you open up your scalelist with SCALELISTEDIT, do you have imperial scales there? You can reset that scale list with the Reset-button - it then loads the default scale list that is set in the registry (if I remember correctly). Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 12, 2015 Share Posted June 12, 2015 1/127" = 1'-0"? That is not even on the list of normal imperial scales for an architectural drawing. Must have been someone's clumsy attempt to apply a scale to a drawing that barely fit the viewport. Most likely they were not aware of traditional engineering scales such as 1"=200'. Quote Link to comment Share on other sites More sharing options...
acjam Posted June 15, 2015 Author Share Posted June 15, 2015 Thanks guys - that fixed it! Quote Link to comment Share on other sites More sharing options...
