jonathann3891 Posted June 12, 2015 Posted June 12, 2015 I'm stuck and cant find a solution. I'm writing a lisp w/ DCL that will draw tee supports. I've got the list to show up in my DCL, but when you select a steel size, its not setting any values that I've stored. Right now I only have 2 steel sizes in the program to try and simplify it. Can someone please point me in the right direction? Some areas I'm sure aren't correct (if userclick (progn (setq $COLSIZE$ (fix $COLSIZE$)) (setq $COLSIZE$ (nth $COLSIZE$ column)) (setq $BMSIZE$ (fix $BMSIZE$)) (setq $BMSIZE$ (nth $BMSIZE$ beam)) ) Set Variables (defun info () ((= $COLSIZE$ "W5X19") (SETQ COLDEPTH 5.13) (SETQ COLFLGTHK 0.44) (SETQ PLTDEPTH 0.75) (SETQ PLTWIDTH 12.0) ) User input (set_tile "toselev" "000.000") (mode_tile "toselev" 0) (action_tile "toselev" "(setq TOSEL $value)") Tee_Test.LSP TPOLE.dcl Quote
Tharwat Posted June 12, 2015 Posted June 12, 2015 but when you select a steel size, its not setting any values that I've stored. Hi, You used the name of text attribute key instead of the popup_list key attribute . Quote
