kunekainen Posted June 16, 2015 Posted June 16, 2015 Hi there; I am trying to write a plug-in which can create a leader (while you are in UCS) with WCS coordinates text. This is what I did so far: <CommandMethod("AddLeaderAnnotation")> _ Public Sub AddLeaderAnnotation() '' Get the current database Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database Dim acCurEd As Editor = acDoc.Editor Dim ucs As Matrix3d = acCurEd.CurrentUserCoordinateSystem Dim cs As CoordinateSystem3d = ucs.CoordinateSystem3d ' Transform from UCS to WCS Dim mat As Matrix3d = Matrix3d.AlignCoordinateSystem(Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis, cs.Origin, cs.Xaxis, _ cs.Yaxis, cs.Zaxis) '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) '' Open the Block table record Model space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _ OpenMode.ForWrite) Dim opt As New PromptPointOptions(vbLf & "Select Point: ") opt.AllowNone = False Dim res As PromptPointResult = acCurEd.GetPoint(opt) Dim pPt As Point3d = res.Value Dim baseWcs As Point3d = pPt.TransformBy(mat) res = acCurEd.GetPoint(opt) Dim pPt1 As Point3d = res.Value '' Create the MText annotation Dim acMText As MText = New MText() acMText.SetDatabaseDefaults() acMText.Contents = baseWcs.X & vbCrLf & baseWcs.Y acMText.Attachment = AttachmentPoint.BottomLeft acMText.Location = pPt1 acMText.Width = 2 '' Add the new object to Model space and the transaction acBlkTblRec.AppendEntity(acMText) acTrans.AddNewlyCreatedDBObject(acMText, True) '' Create the leader with annotation Dim acLdr As Leader = New Leader() acLdr.SetDatabaseDefaults() acLdr.AppendVertex(pPt) acLdr.AppendVertex(pPt1) acLdr.HasArrowHead = True '' Add the new object to Model space and the transaction acBlkTblRec.AppendEntity(acLdr) acTrans.AddNewlyCreatedDBObject(acLdr, True) '' Attach the annotation after the leader object is added acLdr.Annotation = acMText.ObjectId acLdr.EvaluateLeader() '' Commit the changes and dispose of the transaction acTrans.Commit() End Using End Sub Problem is, when i'm in UCS, it creates leader in WCS. So it creates leader in different points from i picked. And leader text is not horizontal. How can i create it in UCS like when i create it in WCS. Thanks in advance. Quote
