dhananjayr567 Posted June 18, 2015 Share Posted June 18, 2015 Dear Sir, I have a data x. y. z coordinate in *.xls format; want to plot in AutoCad as a point, & then genrate contours. please help how to do it. Regards Dhananjay. Quote Link to comment Share on other sites More sharing options...
Commandobill Posted June 18, 2015 Share Posted June 18, 2015 Easiest way would to make a script. Take your excel file and change it to a .csv then change the extension to .scr open it as a text file and change it a little bit so it ends up looking like this: point 0,0,0 point 1,1,1 point 2,2,2 line 0,0,0 1,1,1 2,2,2 Quote Link to comment Share on other sites More sharing options...
Commandobill Posted June 18, 2015 Share Posted June 18, 2015 Then of course typing "scr" at the command line and choosing it from your file location. Quote Link to comment Share on other sites More sharing options...
Commandobill Posted June 18, 2015 Share Posted June 18, 2015 Also, I never used this, but Lee-Mac has a program for this as well. Here Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 18, 2015 Share Posted June 18, 2015 Also, I never used this, but Lee-Mac has a program for this as well. Here Thanks for the recommendation CB - the OP will need to save his XLS to a CSV first Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 19, 2015 Share Posted June 19, 2015 (edited) Most important part guys Autocad can not create contours ! There is no option in plain Autocad. You do though have lots of choices, Autocad CIV3D bring in points as csv and then contour, use a 3rd party product, search here using "CONTOURS" pretty sure YMG3 can help with a contour routine. Found it http://www.cadtutor.net/forum/showthread.php?86040-lisp-to-generate-contour-from-xyz&highlight=contours Edited June 20, 2015 by BIGAL Quote Link to comment Share on other sites More sharing options...
ymg3 Posted June 19, 2015 Share Posted June 19, 2015 Thank you for the recommendation BIGAL. dhanan, For getting the points Lee's program will do it for csv. Jeffrey Sanders has one for xls file IMPORTXYZ.html For contours, you will need first to triangulate your points, then generate the contours. Here is a link to the last revision of my program:TriangV6.4.0.lsp With it, once your point have been imported on screen, you issue command TIN and a DCL will appear to let you do the triangulation and contours. ymg Quote Link to comment Share on other sites More sharing options...
smileforrest Posted September 25, 2015 Share Posted September 25, 2015 When i reach your link ,how can i download your lisp TriangV6.4.0.lsp ? thanks! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 25, 2015 Share Posted September 25, 2015 When i reach your link ,how can i download your lisp TriangV6.4.0.lsp ?thanks! You will need membership at The Swamp in order to view & download attachments. Quote Link to comment Share on other sites More sharing options...
ymg3 Posted September 25, 2015 Share Posted September 25, 2015 smileforrest, Latest published version would be Triang V0.6.5.1.lsp at TheSwamp. This version has depression contour processing added. As Lee stated, you need to register there in order to download. ymg Quote Link to comment Share on other sites More sharing options...
smileforrest Posted September 26, 2015 Share Posted September 26, 2015 when I register I should answer " last name of the CEO of autodesk" ,can u or anyone else give a help? Here I can't get in google. Thanks a lot. Quote Link to comment Share on other sites More sharing options...
ymg3 Posted September 26, 2015 Share Posted September 26, 2015 At the moment the CEO of Autodesk is Carl Bass Quote Link to comment Share on other sites More sharing options...
smileforrest Posted September 26, 2015 Share Posted September 26, 2015 @ymg3 Thank you! Quote Link to comment Share on other sites More sharing options...
